Thanks @scottryana great info. I'm very much looking forward to trying and testing all three locations to come up with the best solution for my needs.
There are a lot of ideas with regard to water/meth injection. The three most common locations are 1) Pre turbo 2) Post turbo/Pre throttle body 3) Intake manifold. Each has it's own pluses and minuses.
1) Pre-turbo depending on how much water/meth you are spraying you have the worry that you could erode the compressor blades. Because the air has not been heated prior to the injection it does not enthalpate as well, but it does cool the turbo (bigger deal on supercharger than turbo charger)
2) Post turbo/Pre throttle body the air is compressed and hot so the water/meth evaporates and cools quickly, but the air could potentially heat back up slightly in the intake manifold.
3) Intake manifold air is compressed and hot, it is closest to the cylinders so least chance of the air heating back up, but depending on placement you have the concern that you don't get equal cooling of the air.
I choose #2 usually.
186 at the base. 216 at the top of the grade.
Ambient temp was 71. 55 mph going up.
I’ve got Joeys modified fan clutch.
I was hoping for 180-190 temps. I’ll have to look into this.
That radiator sounds awesome, albeit uber expensive. I’m guessing in the $1000 + range?No I don’t.
At some point there has to be a determination of cost vs. gains.
what radiator you currently have? If it’s the stock brass one then change it out to aluminum radiators ASAP. Btw if you have a turbo why were you going 55? You need to do 80 so you get the proper airflow, 55 is for people who done have the turbo yet....like me.
I have an OEM radiator that I installed about 7 years & 40K miles ago. I don’t recall what the consensus on the board was the better of the 2 radiators, but that’s what I got.
