This is NOT a photo of our engines/turbo/setup. BUT, it does show what I am considering doing which I think will help a larger group of you instead of being shoe-horned into a single solution. If you look at this downpipe set up, its very similar to what I thinking about doing. There is the V-band at the turbo which goes to a flex joint and another V-band. Then off the wastegate there is another, smaller, flex joint. The flex joints mean there is some wiggle room between trying to keep all of the geometry in line which would be very tough. The thinking now, using this image as reference, to move the v-band to after the wastegate junction. I will keep all reducers to a minimum before this point.
But my reasoning to adding another v-band after that junction is so that the mating pipe could be 2.5" to go to stock setups, or for those that want to goose it, can just bolt up a 3" exhaust to the v-band. This way I don't have to dick around with trying to make more than one solution to make people happy.
Thoughts before I commit?
