Hi guys,
I have some problems on my 1978 FJ40 and hope you can help me.
It´s previous owner installed a 3cm bodylift.
Therefore I had to put a aloy block below the steering box to align/bring back the steering shaft to it´s original position.
Otherwise there would be pressure on the steering coupling because the steering column is not in line with the steering gear box.
This rise caused another problem... There is almost no space between the linkage (which goes from the steering gear box pitman arm to the front pitman arm) and the shocks.
My idea was to find a steering gear box pitman arm, which is a little bit longer than the original one.
It could help to lower the linkage to have again more space.
Can you help me on this topic? Do you know a fitting arm from another vehicle which is longer or do you have another solution?
I would like to avoid welding.
Thank you in advance,
Matthias
