After 6 years of adding components, and never really removing wiring thinking it was fine, it turned out I am not actually "fine". I dropped my mother off at the airport today and was driving home. I was behind a old truck that smelled like smoke. I made a smartass comment to myself and passed him. A few seconds later I realized it was not his truck, but mine. The smoke smell was getting thicker and thicker and then came the smoke. I shut the 100 off and got over as fast as possible and got the hood open to put out the soon to be fire. One of my "dead wires" somehow completed a circuit with a live relay and built up so much heat the plastic melted, and wires caught fire, but did no damage as it was mounted in a bundle of other wires safely away from any hoses or pumps. It lightly scorched the sheet metal.
I drove home, saw a Amazon box at the front door with my Blue Sea Fuse Block, USB outlets, and 12V sockets waiting for me. I was so excited to start installing things I forgot that I had to pull every bit of wiring out. I will be restoring the engine bay and cleaning things up first. Figured it would be fun to document the work here and would possibly help others avoid the mistake that I made.
Here is what is in my truck for the lights, radio amps, HID's, LED's and other things.
3 HID Relay Harnesses
3 LED relay harnesses
2 custom relay harnesses
4 LED resistors on each turn signal
2 Antenna grounds
4 gauge wiring to power inverter
40-50 feet of dead wiring that is not in use.
I'll start with the pictures of todays progress, I removed 100% of the wiring, I had to leave the low and high beam harnesses in place to drive.
My battery terminals are the originals, and have corrosion built up on each terminal severely, causing issues with my accessories. Relay harnesses were not cut to length, just wrapped and stuffed into any open area I could find. I was tapping relays into relays for power. All of the connectors have corroded beyond cleaning, they will be replaced this weekend with new and nicer more appropriate terminals.
Once everything was removed I started to clean and wipe things down.
Battery before and after:
This is HALF of the wiring that I pulled out.
The relay that was not in use that somehow came back to life:
I started replacing my two way switches with a little bit nicer ones, I will continue to replace all switches and mount them in different areas depending on their use.
Everything worked before, surprisingly each switch worked as needed and didn't have any issues. However every time I opened the hood, I felt that I was the kind of person that told people how to wire vehicles properly, yet my truck was disgusting, dangerous, and unreliable. Wiring, Lighting and relay harnesses is my job, something had to change and it wasn't going to by my job...it will be my wiring.
Plans for the Blue Sea Fuse Block are:
All accessories ran through the block properly, labeled, and each wire ran, soldered, and heat shrinked to its proper length.
Two 12V sockets in the cargo area and one in the front passenger area.
One dedicated hot USB socket for phones, Go Pro, and any other USB accessories I may have.
One USB socket in the cargo for camping and running a USB fan, or keeping something charged in the back (camera's in a bag).
All outlets will be on a illuminated master switch so nothing can be left and drain the battery.
TMAX Dual Battery System with a main Group 31 and my current battery as the dual.
Like I said, I am disgusted I let this go this far. Any input or photos would be awesome. It's funny that the day my fuse block arrives, this happens. What a message!
2 Antenna grounds
