landtank said:Cattledog, I just drained it. I'm a big beleiver in no chemicals unless absolutely needed.
Land Tank, with that additude how do you expect chemist's like me to survive!
SUMOTOY said:A proper test IMO, needs nothing to bend other than the radiator fan blades. A proper test needs only two components, clutch lockup and redline.
SUMOTOY said:...I just don't recommend the 10k cst in lockup and 5000rpm engine speeds...
landtank said:Cattledog, I just drained it. I'm a big beleiver in no chemicals unless absolutely needed. I got the same OFNA oil you did only drove to Nashua to get it.
The housing also rotated very easy once the oil was out.
Tools R Us said:So, now your saying that chassis flex, mount flex, body flex, etc. have no effect on fan to shroud/radiator clearance?
And now the ever moving speed of death and destruction up to 5000rpm? It started at what, 4000+ then, 4500, then 4800, now 5000?
The main point being that the foam blocks, placed at the closest spot to the face of the fan, that are as close as I can measure about .5" from the fan and haven't been hit. Showing that my fan flexes less than .5". I have no idea how you flexed your fan 3.5" when it less than 2" from the radiator face stock, but my truck doesn't exhibit this behavior. I ran it again and observed the same, by my old feeble eye it looks to be less than 1/4", and would post the same 3/8" to be conservative and allow for eye ball measurement error.
landtank said:<snip> and 1 truck on 10K without issues. I'd say it's a draw!
cruiserdan said:Make that two please.
LandCruiserPhil said:I come up with 3 with no problems
Tools
Medtro
cruiserdan
I with a lot of problems
SUMOTOY
landtank said:I've just got back from a run with the truck with 5K oil in it and I'd have to say this is probably the minimum viscocity that you should have in your clutches.
Another point was when I drained the old oil it had darkened comsiderably. I don't know what this means, just an observation. The new fill went in clear and I'll check it after some miles.
I'll be changing the initial posts to reflect the oil change.
cruiserdan said:I think maybe 10,000 for blown trucks that are running the smaller blade.
SUMOTOY said:TRU, read the posts from 8-10-05 and the thread I started on 2-10-06. I have said many times that the radiator doesn't flex, but all else does. I also have measurements that appear to indicate that the clearances under lockup at high rpm are tight, with or without a shroud, with or without a SC spacer. I hope it's clear. If not, please reread the original posts with measures, it's in this thread too.
SUMOTOY said:The nice thing about my failure TRU, is there is no 'eyeball' measure, it's perfectly scribed circle in my radiator core. Again, if you read the threads, you would understand that a fan can flex more than interference. I measured core damage .5in into my radiator.
Cage-matchcruiserdan said:One does not want to advance the timing in a blown motor, they are on the edge of knocking as-is.
landtank said:Dan, I was talking about the fan clutch, I ment advancing the timing of the fan clutch by rotating the control plate. That way the clutch comes on sooner which helps it to stay ahead of the cooling demand.
