- Thread starter
- #181
cruiserdan said:You get to be the Ref....![]()
That's no bargain, Sumotoy tends to throw a little wild.
Tools R Us said:I have read most of you "data" and have no need to reread it. In a dynamic environment things flex and move, when offroad frames flex, body mounts flex, the body flexes, motor mounts flex, etc. The radiator is mounted to a different structure from the fan and the flex can and will change the available clearance.
I am very happy for you having that nice "data". I can clamp a fan in the vice, grab a blade with a wrench and get more flex than that, but what does mechanical flexing have to do with a discussion on aerodynamic load flexing to determine clearance?
landtank said:That's no bargain, Sumotoy tends to throw a little wild.
sleeoffroad said:... It looked a little bent. Well, it was about 1.5" bent upwards. ..
cruiserdan said:Some VERY interesting observations this afternoon.
Today was the first "warm" day we have had since my 10,000 change and perhaps this belongs in Sumo's hood vent deal.
I deliberately left the truck idling, with the A/C on and the aux fan off and I watched the gauge. 200, 205, 210, 215, 218....Kicked the rpm up to 1,800 and held it. 215, 210...hold. Kicked the aux fan on, ....hold.
Opened the hood.........210, 205, 200, 195, 190, 185.......
Time to cut some holes.
One more vote for the turbo system!!!
landtank said:I think Dan's biggest issues are the SC blocking the air flow and th eneed to run something other than the stock fan.
Next step might be to remove the rear seal on the hood. This might give some idea if vents would help with the idling issue. You would hate to cut into the hood with little or no positive results.
landtank said:I wasn't advocating the seal removal as a solution but as a next step in determining if opening the hood would help with a truck stationary and idling. I'd also try and determine how much he would have to open the hood to get the relief he needs to maintain the truck's temp. This might be done by just spacing the rear of the hood up.
I'd want to know how big the holes need to be before hacking in some louvers to be sure they will get the job done. Once you know the size then figuring out the placement would be next.
SUMOTOY said:Rear hood raising will work at low speeds, *for testing purposes only* please.
landtank said:I might be off here but his issue is when he's parked, doesn't get that much lower in speeds.
Before I started to carve up my hood I'd do what I could to address my issue. All this talk about louvers and where they need to go as far as when the truck is in motion is all well and good but if your problem is when your stationary the parameters of where the holes need to go might be different.
One thought I had was since his fan sits 3/4" further in the cowling that maybe some trimming on the cowling to allow a more open exit for escaping air might be the ticket.
SUMOTOY said:...
Shroud you mean? As I read current application the deeper you can put the fan into the cowling the more efficient it is (up to a point where shroud vortex interferes). I popped a hood on a new F150 about a week ago. That fan sits much further into the shroud than the 80. And a really deep shroud to boot.
Scott Justusson
Tools R Us said:For our mostly thin edge shrouds the fan is best placed with less than half in the shroud. A shroud with a longer "stovepipe" would be more efficient, ideally the stovepipe would be at least as long as the fan is thick with the fan centered in it. Using a piece of plastic about 2.5" wide bending it around and screwing it into the fan opening would probably be a good mod, making the fan a ducted setup.
On the 80 the fan is almost too close to the radiator, the S/C spacer makes it worse. A powerful large cord fan needs to have room on the front side for the air to flow smoothly into it, the closer it's moved to a surface (the radiator) the narrower the blades need to be. The 80 fan is sized to pull all of the air that can flow through the coolers, so air from the corners is rushing to the front side of the fan and has to make a tight turn, air doesn't like to make tight turns and it becomes turbulent the blades don't deal with turbulent air well and can stall the same way an airplane wing does.
So yes a deeper shroud with a longer stovepipe area is much more efficient, unfortunately the long motor and short snout on the 80 make it difficult to achieve.
SUMOTOY said:Kevin, I suggest that some optimization in front of the radiator could change that. I believe some of that turbulence in front of the radiator can be addressed with honeycomb ducting.
SUMOTOY said:My experience hasn't shown the shroud to increase effectiveness noticeably. I should rephrase though. At low speeds the airflow thru the radiator fan is enough to cool the engine properly.
