- Thread starter
- #201
Tools R Us said:Rick, the light came on today at 227 miles. Hard to tell if there is any change, this tank has the wheeling and 90 mile highway trip home from last weekend on it.
Thanks Kevin
Tools R Us said:Honeycomb or vane ducting is neat stuff and in some applications can yield positive results. What we are talking about here it would have no effect. Look at the blade depth and pitch of the stock fan, compare it to a contact type, like an electric.
The contact type has narrow blades and a small motor, sized to pull the amount of air that can flow through the cooler in the diameter of the blade. For the sake of argument lets say that an 18" contact fan can pull 1000 cfm through the coolers. Now the stock fan is pulling from what 16" x 28"? area and lets call that 4000 cfm.
As the stock fan is moved closer to the radiator it reaches a point where it starts to operate like a contact fan pulling the 1000 cfm that the coolers can flow in an 18" circle. But the fan is trying to pull the extra 3000 cfm that its sized for and that much airflow wont physically fit in the space between the cooler and the fan. So now the fan is pulling a bigger vacuum than it's designed for and the in rushing air from the edges mixed with the air through the cooler and the close spinning blades combine to make a more turbulent environment than the fan is designed for, the airflow breaks down, blades stall and the cfm delivery goes to almost nothing.
I have no problem with data, other than data incorrectly applied is worse than touching and feeling. If you want to test that no shroud and clipped fan is better theory, load your rig and come on out, we will hit Florence Junction on a 110f+ day and see who's junk can hang! I bet that shroud less theory goes up in a cloud of steam on the dirt road on the way to Ajax trail.![]()
Tools R Us said:I don't know what the stock fan pulls and only used made up numbers as an example. The industrial blower engineer who looked at mine did some quick calculations and lets just say that his educated guess far exceeded 4000 cfm.
I really like the experiment, though I had my doubts as to application to an 80. A lot of actual application factors would affect that number greatly.cruiserdan said:
cruiserdan said:I drink Japanese beer sometimes. Would that help?
landtank said:Not to bore anyone with this thread again, but I thought I'd post a little more info.
I was contacted by a forum member who asked me if I'd modify a new clutch for him. He ordered it from CDan and had it shipped directly to me. I got it today along with the 6K OEM oil.
First, the oil from the factory is definately clear and yellows with use. I don't know what that means but it's what is happening.
Second, I evaluated where the clutch was timed and it was set at 115*F, using my method posted earlier. From what I've seen, I'd expect this clutch to cause the truck to run hot during hot weather similar to what Semlin was seeing as it seemed to me timed similarly.
Third, if you are going to do a drain and fill 2 tubes of the Toyota stuff is going to be just right. It came out slightly less than what I originally filled my clutch to but was still more than the factory fill.
I'm still running the OFNA oil and it has been working great as far as contolling engine temps. Later on this fall I'll tear it down and see if it also Yellows with use.
turbocruiser said:Okay, I'm not joking here, seriously not joking, you could make some serious side business doing this for the forum! Let me request a package price for the "Turbo Clutch Tune" - precisely setting temp timing, oil type and oil volume for a FI turbocruiser that runs at roughly 6800 ft, no higher than 14K and no lower than 3K (well at least so far), and almost always at redline (remember no router into radiator effect here okay)!!!
I'll await your word!![]()
Tools R Us said:Have you warmed the valve more, when is it fully open? My truck when fully warm runs 125-160F fan output depending on speed at ~100F ambient, so that 115F setting maybe good?
Beowulf said:Rick,
Is there any research on doing this mod to the original fan clutch? (the one that came on the truck from the factory)
-B-
Beowulf said:Rick,
-B-
