I'd really like to see data on those 3. Are all 3 in this thread? If not can, would you please link them into this thread?
Overheating, is the #1 reason for HG failure in most engines. Possible the UR just running a little to hot, is causes minor warpage and leakage at HG gasket. Then the acidity of stangnet coolant now between HG surfaces, eats at HG rubber coat.
If the issues is defect in material of the HG. Seems we'd see a lot more HG failures. If just one batch of HG, seem be just 1, possible 2 years due to overlap in production timing.
I did hear the CCN guy in a video, indicate: The UR (all UR) engines, has very common HG failure.
Thanks. I take that as a complement.
This blown HG thread, may have not been the best thread for me to post this 2011 blown engine.
"Rivers" My thoughts also. This was a rig from Colorado high country, near a river. To have so much sand in undershielding, would indicate river crossing.
The sand to right, was also in undershielding. Which much of became mixed with oil and water.
A at this time. I do not think this 2011 busting out oil pan. Was from overheating or and blowing HG. Since Radiator full and reservoir levels mid range at 60F.
PO had for ~15 years (purchased with only 5K on OD). He and his teenage son(s) dorve. Engine blew, while son driving, in deep snow.
I'm hopefully, going to talk with PO soon.
Here's what I like to know:
- How often were the 3 radiators, fins cleaned?
- Any overheating or fuel boiling event(s), ever?
- Was coolant being added, to keep reservoir and or rad full/topped off?
- What oil was used, and any change over the years?
- Was there any audible change in sound. Especially within first 10 minutes of a cold start. (Timing chain rattle, lifter tap (bad valve spring)).
I suspect a busted rod, in this blown engine. Since something busted oil pan out. In the debris, I recovered a "likely" wrist pin snap ring. Also likely" piston oil ring & its spacer.
View attachment 3892132View attachment 3892131
Part number changes, can yield clues to defect. But!
But. Toyota changes P/N often. Even which country I pull parts from, make can make difference. These changes can be a design or material change, to improve a part. But More often are new supplier. The change is to make or use, over more models and years (streamline inventory).
I've seen some P/N change 1/2 dozen times or more times. Without any failure of old parts.
@OGBeno could possible shed the most light on 3UR head gasket part number change
I'm also very interested in valve spring a chain tensioner.
Can I ask a few question @WildYoats :
How often did you check coolant level (look at reservoir level and under radiator cap)?
How often did you clean all 3 radiator fins (in all 3 directions/angles)?
Did you watch engine coolant temp, through tech stream data?
Any fuel boil events or excessive fuel smell?
No CEL or not seeing dash water temp needle peg at top or go above much midway. Doesn't mean never overheated or didn't run engine hotter than optimal op temp.
Again IMHO: If a batch of HG bad. One would think. It would be limited to, one or two years of engine production.
