BJ42 refurbisment (2 Viewers)
Here is a poser before pic, didn't look bad from a distance.
The second pic is before I got new to me doors and before I put the current lift and tires and is pretty close to the condition I got it in
rear diff coming apart
the backing plates are toast
the brake lines are toast
the e/brake assembly include cables is toast
new towers, cables, boots, backing plates, etc etc are on order ...
brake drums have been turned, lots of meat left
shoes are fine
the complete assembly will be PC to resist Eastern State rust issues.
front springs coming apart to get PC as well as shim of neo to promote spring flex and longevity.
<yes, i investigated PC leaf springs and it is 320 - 360 degrees for 18 - 24 min and it won't affect the arch. if you go typical 450 degrees for 15 minutes then the heat MIGHT affect the arch>
the frame is salvaeble but still quite rusty
between the two frames one good one can be built ...
tearing the front diff down, lots of rust, brake lines are shot
the front hubs have been serviced recently
the backing plates are done
rotors have been turned now
the front end will be PC as well
that is it for now
cheers and thanks for following along.
It seems like on the first page that the dash was sorta unscrewed from the firewall - is that how it's attached?
The tub looks like a fairly faithful duplication of the stock unit. Will be following along this thread -keep up the good work!
[EDIT] Just checked out the Gozzard site and saw a pic of the dash, which is riveted on. That would make accessing up behind the dash pretty easy. I wonder about doing it with Nutserts or something similar?
the manifold painted with high heat black
once we found the flange, reamed it out to fit and had a piece flared to fit over the raised step we painted it black as well.
the pyro will be fitted to the manifold.
the turbo kit.
there were issues with the kit:
there were 4 boxes that were sent, it took over 6 weeks for them all to arrive
the exhaust manifold gasket was missing
the 2 longer exhaust manifold bolts were missing
the adapter between the manifold and the turbo had studs too large for the turbo recieving holes making drilling the turbo out to fit.
the exhaust manifold bolt holes were wrong pitch for bolts supplied
no instructions were included
no cross over pipe was included
no ducting from the air box to the turbo
the boost line was too short
no flange for the turbo to exhaust pipe
no bolts for the flange
all in all, i am unimpressed with the "kit". i do hope the performance is as suggested.
to be fair, most of these issues are not Diesel42's fault. the shipping was screwed up by the sub-suppliers. s*** happens.
i have made some suggestions to Keith as to how to make the kit more user friendly, it is up to him whether it will happen or not.
O'kay this was Waynes side of the story now i'll give you ours:
"there were 4 boxes that were sent, it took over 6 weeks for them all to arrive"
As all of you that we've supplied thhis kit to knows, we ship some of these parts(turbo,manifold, and silicone hoses) directly to you so you don't have to pay additional shipping from the supplier to our shop then back to you. Because this kit was sent to Canada, some of the parts got hung up in Canadian custums. We supplied the shipping info and tracking# to the buyer. Nothing we can do about that.
"the exhaust manifold gasket was missing
the 2 longer exhaust manifold bolts were missing"
There is a OEM Toyota gasket with the two special bolts sent with the 13bt manifold from our supplier. Wayne said he didn't recieve them therefore, I immediately contacted them. They said they double wrap the gaste for protection and asked if I would relay that to Wayne to check which I did. He replied that he couldn't find them and reordered his own.
"the adapter between the manifold and the turbo had studs too large for the turbo recieving holes making drilling the turbo out to fit"
The adapter is CNC machined to exact tolerances per Garrets blue prints. Because the turbo is a case piece and factory jigging the center section for perfect drilling isn't as accurate, sometimes one or more holes needs to be reamed with a slightly larger drill bit so that the four holes can slid down over the adapter. The studs were not to large.
"the exhaust manifold bolt holes were wrong pitch for bolts supplied"
As many of you know, Toyota stopped production of the factory 13bt manifold. Myself and two Canadian suppliers joined forces and had these reproduced overseas. The first batch that arrived have the wrong thread pitch which did not get caught in quality control. Those that got these found this out. Shouldn't have happened and has been rectified. We have spent alot of time and money to make these available to the LC guys.
"no instructions were included"
Instructions have never been available in over 50 kits over the last few years as it is really self explainatory and anyone that has bought this kit knows, I go out of my way to answer questions on my time and dime(phone calls) to answer questions. Wayne was provided my phone # however never once called.
"no cross over pipe was included"
The crossover pipe is just a 9" piece of 2" aluminized exhaust tubing that is available at any exhaust/muffler shop in there cut off pile(usually free). Because of its size, we were having to ship in a larger box which raised the shipping. When we calculated the increasse coupled with the cost of buying a stick of tubing and cutting it,etc. It was really cheaper for the customer to get it when they have there exhaust done(again usually always free. I expain this when everyone orders.
"no ducting from the air box to the turbo"
This too is also explained to the customer. Reason: There are alot of vehicles the B-series engines went in to. We have no idea what air delievery system each customer is going to use. Therefore how can we supply parts.
"the boost line was too short"
From the pictures, you've got the center section upside down. Both the compressor and turbine sides are fully clockable allowing the center section to rotate 360deg. The wastegate bracket can also be moved. Again, I offered to contact Garret and have a longer piece sent to him. He replied,"Dealt with".
"no flange for the turbo to exhaust pipe"
Again, Garret doesn't supply a exhaust flange as they have no idea as to what size exhaust each individual customer is going to use. Neither do we. These are triangular three hole rings that every exhaust shop uses.
"no bolts for the flange"
Answered previous
Most that know me are aware that I own a protoype and design machine shop. We don't make turbos. I built this kit for my LC some years back. Then guys kept asking if I would supply the parts as a kit I agreed as this forum has been so good to me. We sell usually 2 kits per month. I don't stock our shelves and front valuable working capital with thousands of dollars worth of turbos,manifolds,steel braided lies,silicon hoses,etc. I would have to ask alot more if we did. So, when a order comes in, we build the adapters, gaskets,bolt kits,oil and drain lines,fittings,etc,etc, then ship it. We order the turbo,manifold kit,and silicon hoses from our suppliers then have them dropped shipped directly to you to save you money and increase shipping time.
So, in over fifty kits, never EVER has there been a missing gasket or bolts,etc. Never has there been a complaint(actually one but for another reason). They've gone to the U.S.,Canada, Ireland, South Africa,New Zealand,Austrialia,Mexico. Not one person couldn't source a exhaust flange appropriate for there specific exhaust. Even a lady mudder(i'll leave this up to you if yoiu want to be named) installed the kit without problems. Nobody has had this many issues. Most of which could have been easily resolved have you simply asked. Take the oil port for example. The adapter we provided has the correct British Standard pipe pitch and taper to match the block. Because Wayne was to proud or cocky to ask, he simply stuffed a National Pipe tape through it. So if it leaks or fails and the owner loses his oil, he'll probably blame me on the forum.
I am beside myself at this thread. And hoonestly am considering stopping the tubo kit sales. They are time consuming and not profitable. Again, i'm the owner so I can get away with directing company time to build a kit for a fellow mudder. But to have to defend myself under these circumstances by this guy offends me beyond belief. I have the correspondence between Wayne and my shop if anyone wants to read his snooty emails.
The manifold did have the wrong thread pitch. If he would have called me, I would have sent him a tap or made it right for him. EVERY OTHER PERSON managed this fine and understood it was a manufacturing flaw. But were very appreciative that we stepped up and had these made for them.
Wayne, i've already had two phone calls from members regarding you and this thread. Your reputation PRECEDES you. I am not going to proof read this rather just hitting submit so I won't relive this post.
Kieth,
as I said, s*** happens.
it just seems that it happened to this kit.
i called 3 times when i started to test install this kit. no answering machine, so i "dealt" with the issues myself. no biggie.
i don't have the time right now to wait for another gasket or bolt to be shipped over. i can do the sourcing if need be.
mistakes happen, things get missed, orders get delayed, things beyond your control ... everyone in business knows this.
whether you want to stop supplying the kit due to one unhappy customer (and 50 happy ones), that is up to you.
or, you can take the SUGGESTIONS and make a more complete kit. that is your call.
I have sourced the turbo, i have sourced the manifold, i have sourced all the neccessary parts to build the next 3 kits i need.
<and NO, i will not be supplying a kit. i have too much to do to invest time in such an indevor. This is Keiths gift to the community and i will not entertain the idea of stepping on his toes>
i have orders for 4 kits total, (including Brian's), that i need to have supplied before August. IF this kit would have arrived on time, if it would have been complete to my satisfaction then i would have saved my time to source all the individual pieces and just ordered from you.
I actually enjoy supporting those that support the community and if i wanted to improve the power of a 12HT, HDT or any other Toyota that needed just the turbo swapped out then i would be very happy to support you and purchase one of your kick'n turbos.
but
i bought a "kit" and it wasn't complete.
it isn't a dig against you.
it isn't a unfounded accusation to detract from your honor.
this post was a point by point list of what could be done to improve the kit (especially for those that live in the boonies).
side note:
the most frustrating part was the missing exhaust flange, I had the turbo taken to 6 exhaust shops to get a flange. My helper finally found a place that had a flange that had the right bolt pattern and Ryan was able to remove the material from the flange to allow 2.5" pipe to fit.
IF it is so easy to find the part then source out a number of them and include one in each kit with bolts. a 6" piece of flared exhaust pipe and the installer has something to work with.
you can't go 3" right from the turbo anyway due to the bolt location.
2.5" is tight but doable
the installer can do a reducer should he want to run factory 2" exhaust.
take another look at the last pic in post 4, the center section is clocked correctly, the inlet side needed clocking yet.
this is not a thread to bring you down in the eyes of the community, it was posted to help others to prepare and what they will need to complete the "kit".
and yes, my reputation of calling it as it is does preceed me.
i beleive i was fair in my post, if i wasn't in any of the points then let me know and i will be happy to review it again.
cheers and peace.
Hello Wayne,
wrong thread pitch in manifold (dealt with)
We found this out after our 15 manifolds we were allotted were sent out. As there was quit a wait for these, they were shipped directly from EBI to the customers. Unfortunately no one caught(our Canadian supplier and EBI) it so the bolts that we sent had the correct pitch wouldn't fit. That was addressed to the new manufacturer.
wrong diameter in adapter studs (dealt with)
Sometimes the holes on the Garretts casting are tight and need to be reamed with a drill bit as the adapter is a very precision and snug fit. Some slip fine others need the holes done. The stud diameter have always been the same.
missing exhaust adapter from turbo to exhaust piping. (important)
This piece does not come with the kit as the exhaust and the intake are left up to the builder. As you are aware due to the several different vehicles the 3B was used, the intake/air cleaner design is different. Same with exhaust, it is unknown as what size exhaust they are going to run. The majority of guys go with the 2-1/2" pipe. A short 90deg. is bent then cut at the turbos exhaust. A triangular ring is slipped over the pipe and the pipe is flared to match the male flare on the turbos exhaust casting. Then bolted (or with studs) are used. Garrett doesn't furnish a universal type exhaust flange. Muffler shops usually have a host of these rings in various sizes depending on the exhaust size choosen.
missing exhaust gasket from manifold to engine (to reuse is a poor practice)
Agreed. You should have received a OEM Toyota gasket from EBI with your manifold along with the two longer bolts for the thicker lower mid section. They have always sent all these together. I will call them tomorrow, that shouldn't have happened.
intake crossover pipe missing (small detail but would have been nice)
We used to buy lengths of 2" exhaust tubing and chop off the 9"'s and ship it. A couple got dented in shipment so guys said they would get it from there exhaust shop when they did there exhaust which was usually free. So we left it out and removed that cost from the kit. This is explained to everyone when they purchase, Brain my have forgotten.
wastegate hose too short (frustrating small detail)
Not sure on this one as we also had that shipped directly from the distributor. But it wouldn't have been opened since it left the factory. That has never happened. If it is not usable let me know and i'll contact Garrett about a replacement. The turbo is fully clock-able(both compressor and exhaust) as is the wastegate and wastegate bracket which can also be lengthened or shortened. Maybe this will allow the factory hose to fit. If not we'll fix this.
missing adapter from air box to turbo (easy enough if you live in a city but when you are 3 hours away it is a PITA)
As with the other turbo kits manufacturers, the intake is left to the customer and there preference(stock air box,after market,etc.). No universal standard.I will contact EBI tomorrow regarding the missing gasket and bolts. This should not have happened as with the mistaken tapped holes in the manifold. This has been a s*** show for sure. Usually the shipping goes fine, and every part is there, and only minor fitment issues. I apologize for those mistakes. When Toyota dropped the 13bt, it has been a nightmare going through the re-manufacturing process. I have been assured the new ones are going to be perfect(of coarse, the price went up. But if you decide you want the next kits for Brians build I will not charge him any extra) rather I will eat the extra costs for your troubles. The new manifolds are supposedly under way with a delivery date in July. Still waiting to get the exact arrival date..I hope I've answered all of your questions. Feel free to ask if I didn't.
Keith
WBMachine Co
Morning Keith,
yah, it has been an interesting experience.
everything but the exhaust plate is easily dealt with, I have contacted a local machine shop to make me up a proper exhaust flange so I can weld the exhaust pipe to it. we have had no luck at any of the exhaust shops in the area, we have tried farm, industrial, truck and normal car shops ... frustration is setting in. to make it easier for the DIY,supplying that piece would be of benefit.
no longer bolts came with the manifold
no gasket came with the manifold
to be honest, at this point, as it sits now I can not recommend the kit. I REALLY hope the end performance is as claimed.
cheers
Wayne
Keith,
I checked twice with each piece to see and nothing was here.
it seems that I might be the guy that every company ends up having where everything that can go wrong, does.
I finally sourced the mounting bracket, I needed to tweak it a bit but I can now run the exhaust system. (dealt with)
I have the gasket on order (dealt with)
the bolts are on order (dealt with)
so life is back on track.
cheers
Wayne
snooty? seriously? i had issues and dealt with them ...
<shrug>
you can rivit the dash on but i use tiny bolts.
it is a nice setup, if you look at the HZJ40 build you will see that you have easy access to the back of the dash to insert the different gauges, wiring, etc etc.
actually if one was to make quick connects to the wiring harness at each end then you could remove the dash completely to do any repair or mod work you would want.
i did this idea with the upper console for the troopie and the BJ70 work truck wiring. it makes for much easier and cleaner installs.
the tub is second to none for a rust free body. there are steel tubs for sale that are more detailed.
other than the rear floor missing the ribs and the way the wheel wells are created in the rear it is hard to tell from factory.
Brian also went with the full Gozzard front doors and you would be hard pressed to be able to tell them from stock ... even with the inner door panels removed. every piece of webbing was reproduced into the doors.
when you get Mike motivated, he does AMAZING workmanship.
Wow! Lol. Nice to here both sides here. I have spent some time in performance shops as well as dealership line of work. If you want oem fit DON'T install an aftermarket kit on an engine that wasn't meant to be boosted in the first place. Anyone doing this should be fully aware that modifications are needed to make something like that work. I have installed plenty of turbos on high hp hondas and the complaints mentioned were something that should be fully expected with an AFTERMARKET turbo install. Honestly the only thing that bothered me (Scared really) was retapping the block instead of using the correct bspt fitting which is readily available.
BJ 42 getting restored , awesome work as usual !
Gozzard body Nice!
I hope you destroyed the caterpillars . Right now as we speek parts of the Kootenays are becoming de-foliated from them .
Thanks Wayne for once again allowing us inside your shop to see the work you do as it progresses.
Being "open" like you are has it's drawbacks. Many of us can recall another build you did where the owner took receipt of his re-powered 40-series and proceeded to list the faults he found with your work.
But when given the choice, I prefer to use someone like yourself rather than "the alternative" (who is more "the norm") and who generally performs all their work out-of the-public-view and goes to great lengths to present a one-sided positive image of themselves. (If they show any of their work at all then it'll usually be "completed showroom jobs for special clients". And they tend to give high profile clients more favourable deals at the expense of their regular clients - again to ensure they project "the perfect business image".)
So Keith (Diesel42) .... While I think I can understand how you feel right now (that your kit has been unfairly criticised and that you've been personally slighted) ... I think it's just an unfortunate side-effect of Wayne "opening up his workshop to a wide audience" and his "freedom of expression". I've bought your products so I know your concentration on quality. (OK. It was just a diesel badge .... but it still serves to show off your machining excellence.)
Other turbo-kit suppliers haven't been placed in the public spotlight like you have here ... but a prospective purchaser would be silly to believe that their products are better than yours because of it.
Well that's my take on all this (for what little it's worth)anyway .....
:beer:
Please carry on Wayne........ (I might not be a turbo-freak but I do like to watch your work.)
Keith,
-i did not "stuff" a NPT into the hole as you accused me of. i installed the adapter that you supplied attached to the hose.
to clarify, i didn't re tap the block per say, i widened the hole (pipe thread, the deeper you go the wider the hole) so the adapter (you supplied) would fit snug into the block instead of catching by a few threads. i have done this practice on dozens of turbo installs over the last couple decades and never had a leak.
the NPT and the BPT are the same thread pitch but different diameters.
-<and curious, since you are a machine shop, how do you take a coarse spline thread in an adapter and "re-tap" to a fine spline properly?>
-you stated that items "were held up at the border" since it was being sent to Canada but:
Hello Brian,
I just received a email from the delear that supplies the silicon hoses and parts informing me that yoiur order was backordered and has now shipped. In addition, an apology as we were told the order had already shipped on 4-25-12. Apparently it hadn't.
I am sorry this happened as it shouldn't have. Which parts have you guys recieved?
Keith
WBMachine Co.
Hello,
Thank you for your recent order from Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts. Unfortunately, the 2.0" Silicone Hump Hose, Blue you ordered is completely out of stock. This was an inventory mistake on my part. I apologize for this error. You may have erroneously been notified that your order had shipped. Would it be okay if I shipped the rest of your order and issued a refund for this part?
The order is On Hold until we hear from you.
Thanks,
Carol
the only reason i posted this email up was to refute the claim that i am being snooty.
(you apologised to Brian but neglected to acknowledge the issue in this thread)
-as i stated in the original post, mistakes happen.
-the exhaust gasket and bolts did not arrive, i never claimed a credit. i never demanded the parts to be sent out. i sourced the parts and dealt with it.
-if you use M10 studs in the adapter plate you would not need to ream out any holes in the turbo housings.
i posted MY experience with the "kit". as i mentioned, i can not recommend this "kit". MY experience with the timing of the parts, the missing parts and now the response from Keith has left me with this recommendation even more firmly ingrained.
Lostmarbles, if you take a look at the troopie build you will find i did an honest appraisal of the Safari turbo kits that Radd Cruiser sells. I don't play favorites, if i see a fault or feel there is a better way then i mention it in the thread.
There were two reasons (that i know of) for Brian to want to use Keith's kit, cost and performance.
By the time the run-around time is added in, the saving between the two is not that great.
I know the performance of Radd Cruisers kit. (decent)
i know the performance of my mapped turbos. (decent)
I know the performance of the 2LTE turbo installed on a 3B (very close in sizing of Keith's turbo). (decent)
I have not experienced Keith's kit on the road yet. It will be interesting.
Yes, the HZJ40 was an eye opener for me and i learned some lessons from it.
When someone wants something rushed ... don't. it will end up biting you in the ass.
When someone wants to register a vehicle BEFORE the final payment ... don't. you will end up losing money.
When someone complains, listen. There is a lesson to be learned.
once again, my initial post was not a dig at Keith.
in all seriousness, in 50 3B "kits" he has sold, sooner or later there would be one that had issues. it seems that 'one' was mine.
my original post was a list of errors and items that i feel could be included in the kit (at a very low cost) to make it DIY friendly.
Hello Wayne,
Good to see another build of yours. Does the tub have the rear "beer compartment"?
I understand your feelings about that turbo. Sometimes you can handle the unexpected, sometimes you cannot.
And it is better for the supplier to know, in order to avoid problems.
Just my opinion.
Juan
we are using the diesel42 turbo system on this one
AKA the Dougal42 turbo. :hillbilly:
BTW, BSPT and NPT are different thread forms. You will need sealant to stop that hole leaking.
Juan,
the owner had debated about putting a rear "beer compartment" in but with the custom fold up rear seat arrangement it wasn't really practical.
Hello Wayne,
Just my opinion.
Juan
