I've had the 1F engine out of my 71 FJ40 for over a year. The machine shop cleaned, bored cyls. .020 over, .010 off crank, installed cam bearings, rebuilt head and milled deck. I bought my bearings from SOR and replacing cam and lifters. I've inquired on this forum about the .20 / 8mm shims found under the bearing caps and have gotten good replies from a few a nice and helpful folks. My problem is that the damn crankshaft is binding when I turn it with a wrench on the crank nut and will barely budge when forcing the counter weights by hand. I have correctly placed the bearsings, torqued them in sequence with a light coat of only on the face only. I have measured the crank journals over and over and and they are within spec for .010 under crank. I've tried to measure the ID of the installed and torqued bearings but I don't trust the cheap plunger type ID guages I have. I've used a ton of plastigauge and seem to be in tolerence for oil clearence but the binding scares me to death. I've installed and reinstalled this crank so many times, I'm sick of it, including isolating particular sticky journals and seem to jump from bearing to bearing. I've gone to a local expert that restores investment concourse cars to 70's muscle cars. He told me to give the bearing caps a "hard smack" with a heavy hammer to "nest" the bearings, otherwise, he has no interest in what he calls my "basket case". It's obvious that most of my local machine shops are run my younger guys and there a few with old guys, my age, that have the experience with older type engines. I've got over $2500 in parts and machine shop costs. The engine had 2 broken rings prior to disassembly @ 180k original miles, but was otherwise in good shape.
Does anyone have a procedure for starting from scratch to figure out what's my issue? I'm sorry I didn't farm out the rebuild, but I'm not so sure someone else wouldn't have assembled it tight.
