Bilstein B8 5125 rear fitment
Phoenix, AZ
Anybody know if these will fit a 100 with 1-2" lift? The lengths seem in line with other offerings.
Bilstein website says 5/8" hourglass eye bushing (not sure if that's what we have) and top stem mount.
Seeing a few lengths in 2 valving rates... the ones below caught my eye.
P/N 33-230337
Collapsed Length (IN) 15.01
Extended Length (IN) 24.38
Collapsed Length (MM) 381.3
Extended Length (MM) 619.3
Compression @0.52m/s 650
Rebound @0.52m/s 2500
P/N 33-230412
Collapsed Length (IN) 15.19
Collapsed Length (MM) 385.8
Compression @0.52m/s 840
Rebound @0.52m/s 3695
Would be interesting if these fit, I could use a set of new rear shocks...always read the only limitation of bilsteins was the length but these seem to be perfect
@Somebodyelse5 do you know the lower mount specs?
I can't find much of any published specs on the OME 60002 shocks, I was hoping that we could use them as a comparison.
The rear lower shock mount is most definitely an hour glass bushing, but we can pull one out this weekend and have a look if you want?
