Bilstein 6112/5160 Installed (11 Viewers)
Due the the parts guy ordering 2 rights (I’m the parts guy 😏) I used 2 right rear shocks. I had zero issues. On the left side the resi bracket just faces in instead of out. I don’t think installing them backward will result in this issue with the sway bar.
This is the way mine are installed. Plenty of room between shock body and swaybar. The GCC spec may be different though.
It does look like yours are installed on the wrong side.
Even though I have an LX, I have a thing for Bilstein suspensions. Maybe because I have Bilstein's on my other rides.
Of anyone installing these could take full droop hub to fender measurements, I'm curious what kind of additional suspension travel these might give.
I suspect the non-KDSS sway bar and apparent outward curve to get it to line up with the frame rail is responsible for the interference. Did you confirm with Bilstien that this setup is compatible with non-KDSS cruisers?
Got all the parts in for the install, i read somewhere that the factory front coil spacer needs to be removed for proper installation of the fronts, is this correct?
US models don’t come with it from the factory.
Good call.
@Colby Murphy Perhaps with a minor adjustment of the sway bar link or bracket, you might be able eek just a bit more clearance to make this work. Looks like the contact is only a problem on full droop? You may be able shim the drop link at the chassis side with a stack of shims/washers, utilizing some of the extra thread to lower the link and sway bar enough to avoid contact? And/or shim the chassis bracket lower? You may even be able to source a longer link, or modify this one to suit?
@DomSmith - when time allows...what are your center of hub to fender measurements with the +1 front (perch #1) with OEM springs?
My set is coming in a few days.. Maybe I missed this but what perch setting in front will result with 1.75" of lift? Mostly stock for now only a rack and a second battery tray coming in a few months. I will be installing OME 2721 in the rear and from what I read they will provide 1.75" of lift, is that correct? It is my daily driver with not much weight in back but for trips the back gets loaded with 500lb of gear. I am looking for a leveled setting when unloaded. Any info before I commit to a perch setting would be appreciated, thanks!
Based on the documentation you would be looking at perch setting #3 for a 1.8” lift in the front. Not sure on the OME springs.
I also went with 2721 springs. See my quoted post below. I have about 0.75" of rake on setting #5.
Depending on how much rake front to back you have currently, may need more lift on the front to get it leveled.
Coming right up. 4WP see last sentence :p
Final lift amount 2.25" up front (#5 clip), 1.5" rear. I still have third row seat.
Still waiting for everything to settle to do alignment. I maxed out the cams currently to get the most caster.
Hub Center to FenderBeforeAfter
Front​
19.5"21.75"
Rear​
21.0"22.5"
