Better than OME, and Ironman FCP?, yes. I have had those setups in the past on other rigs. I don’t have experience with tough dog, but I think it’s comparable with the Ironman FCP. I would say it is still worth it. It’s a big jump to the next next level ofFor people that have these, with the price increase are the Bilsteins still worth it over the competition? (say OME, Ironman FCP or Tough Dog)? I was about to pull the trigger then got busy with other things. Pretty disappointed to hear about the price increase and now having second thoughts.
Man, no after pictures.....I just installed the Bilstein set with OME 2721 rear springs over the weekend. It's hard to compare to the other offerings without trying all of them. General consensus is that the OME (non-BP51) is too stiff. Tough dog / Ironman foam cell is better than Bilstein for off-road conditions. Toughdog 45mm adjustable was my 2nd option. If you were local I would offer you a ride.
Based my 100 miles initial impression, on highway performance is awesome. No more brake dive under medium braking load. No more wobbliness and secondary motion/oscillation. I installed the fronts first and test drove it with the OEM rear shock/spring. It felt really controlled, firm but not harsh. I was grinning ear to ear, kinda reminded me of my 2016 Sti. I also have a ARB front bumper with winch, which is perfect match for the 650 lb/in spring. Best way to describe: it feels like a german car and not a Buick.
After installing the rear 5160 shock and OME 2721 Spring (270/350 lbs/in) the car felt even firmer. The OEM springs are 170 lbs/in. Highway performance is still awesome. However the bumps/pot holes are rougher. This is due to the higher rear spring rate. Loaded up with 4 adults + baby + gear, the car felt more comfortable. The 200 is mostly on family duty since I use a cushy LS430 for daily. I felt the heavy spring was needed when we load it up with people and stuff.
I would recommend staying with the OEM spring (170 lbs/in) or the Bilstein spring option (also 170 lbs/in, 1.75" lift) if you don't plan on having a lot of weight in the back.
To summarize, I ultimately chose the Bilstein due to: lower cost, simpler and better on pavement performance (I think). I ordered through 4 Wheel Parts, they gave me the best price. PM me for the contact info if you'd like.
Here are some pictures:
Where did you buy them from?
| Hub Center to Fender | Before | After |
Front | 19.5" | 21.75" |
Rear | 21.0" | 22.5" |
Coming right up. 4WP see last sentence
Final lift amount 2.25" up front (#5 clip), 1.5" rear. I still have third row seat.
Still waiting for everything to settle to do alignment. I maxed out the cams currently to get the most caster.
Hub Center to Fender Before After Front19.5" 21.75" Rear21.0" 22.5"
Looks great and what a cool little neighborhood.
Those look like 285/65/18 KO2s?
Who makes that spring compressor?I just installed the Bilstein set with OME 2721 rear springs over the weekend. It's hard to compare to the other offerings without trying all of them. General consensus is that the OME (non-BP51) is too stiff. Tough dog / Ironman foam cell is better than Bilstein for off-road conditions. Toughdog 45mm adjustable was my 2nd option. If you were local I would offer you a ride.
I despise the rentals, so thanks a ton for this infoBranick
Model 7600 Professional Strut Spring Compression Tool - Branick
Known as "the standard in the industry," the 7600 handles the heaviest coil-over-shocks on light trucks and SUVs without needing additional adapters. It also has longer handles for extra torque. The multi-position upper spring hooks can be arranged for ultimate flexibility to fit "factory" coil...www.branick.com
I found an older 7200 version locally. Makes compressing the heavy springs much safer than the autozone rentals.
^ This is exactly what I have on a ‘16. The ride is much improved over the OEM setup. My wife used to call it the marshmallow mobile based on the sway and squishy ride. Definitely stiffer and the truck no longer rolls side to side on curves. Can do speed bumps at any speed (if you want).
The other part of the stiffness that I feel is the BFG tires. The sidewall stiffness transmitted bumps much more than the stock tires. Did that swap before any change in the suspension.
I also have airbags for rare towing.
Here’s how the truck sits....
Tires are 285/70/17 BFG ATs. From one of the many tire size threads here it’s the largest tire I was comfortable using that folks said would fit in the stock spare spot under the truck.
No rubbing with stock suspension. No rubbing with Bilstein 4600’s with front leveled. No rubbing with the newer Bilstein setup.
