- Joined
- Jun 15, 2014
- Threads
- 32
- Messages
- 368
- Location
- West Cochise Stronghold, Arizona
- Website
- www.exploringoverland.com
Now that our FZJ75 is in the states for a while, there are a few things I want to do to it, and high on the list is to improve the braking of its four-wheel-disc system. My first move will be to install DOT 4 or 5.1 brake fluid, semi-metallic pads, and possibly braided lines. However, the real improvement would come from installing larger-diameter or wider rotors. Installing multi-piston calipers by themselves is pointless. Drilled discs do nothing to reduce fade. Heavier stock-sized discs (for example, with extra cooling vanes) would also help. Does anyone know of an aftermarket source or a bolt-on Toyota swap to achieve this? My approach stems from an article I wrote on Overland Tech and Travel some time ago (here) about the myths of so-called high-performance aftermarket brake kits, many of which are no such thing. P.S. I really want to stay with 16-inch rims. Thanks for any experiences or direction.
