- Joined
- Jun 21, 2011
- Threads
- 233
- Messages
- 21,804
- Location
- Redding, California
- Website
- trail-tailor.com
BP51's were my next choice. Though I can't really see how a foam cell and remote res work together... is the res foam filled? Also, are they bypass like the BP51? In either case, OME is taking their sweet time getting the 80 series BP51 released so it will be a matter of availability and cost WHEN it happens.
A foam cell shock is an oil filled foam sleeved chamber not a hollow gas filled chamber. I have this conversation a lot and people don't understand that its not solid foam that cushions the shock. The foam sleeve acts as a neutralizer for gas/liquid separation. Oil takes longer to heat up than gas and therefore a foam cell shock stays cooler.
Tough Dog explanation: (IronMan's terminology is similar from my readings)
"The ‘Foam Cell’ that makes all the difference is a micro-cellular foam insert that helps to drastically reduce the effects of shock fade, allowing your shocks to perform better for longer, even on the harshest of corrugations. Cavitation and Aeration are the undoing of any shock absorber. As the shock is worked harder, the oil and gas in the outer chamber begins to mix and form bubbles, lowering the viscosity of the oil. When this aerated oil passes through the valve, there is reduced resistance, stopping the shock fromm performing correctly. The Foam Cell insert, with its trapped gas micro cells takes up the empty space in the shock normally taken up by air or nitrogen gas. This eliminates the possibility of bubbles forming, allowing the shock to get on with the job with an unparalleled resistance to shock fade."
Hey its an "advertisement" but other than forum blah blah... at least they try educate the public in a world wide aspect for people to actually see and try relate to.
J
