Baja Design fog lights (2 Viewers)
For anyone looking for another alternative the DiodeDynamics kits are almost identical and their DOT/SAE lens has a razor sharp cut off. The pro's are insanely bright but the cut off is low enough that I never get flashed by other drivers. These are truly a fog lens, if you are wanting something to augment your low beams these are not it, they cast a very flat wide beam which is incredibly effective in actual fog rain and snow but if you aim them up so the cut off is level with your headlights the bottom of the beam won't even be illuminating the road where you need it most in adverse weather conditions. I leave them on always.
See post 8. Squadron R Pro Amber Wide on my 4Runner, but they're now on my LC in place of the OEM fogs. Way too bright for use it traffic. The SAE versions may be a better all-around fit, but they were not out yet when I got mine.
Might as well blind away. I already get flashed non-stop and I don't even have a lift or aftermarket fogs.
Well those are interesting, LED fogs with a cut off. My friend with a '20 HE was given some work lights, and I installed them behind the grill as cornering lights. They work well in the location, but I wish they had a cut off.
View attachment 3158256View attachment 3158257
The Diode Dynamics are great lights. They also fit most aftermarket bumpers that come with the 4” round lights. The cut off is sharp and work great in the snow also. Have been impressed with them.
Love the output, is this the Tundra Max kit?!
Here is the stats from my order: "SS3 LED Fog Light Kit for 2016-2021 Toyota Tacoma, Power Level: Pro, Lens: Yellow SAE/DOT Fog" this kit was direct plug and play for the 2013 LX570 stock fog locations. However when I installed my IronMan front bumper I ordered new Flat/Round light bezels. The ones in the Tacoma kit have an angled bezel that would have looked a little weird in the IronMan.
This definitely wasn't a plug and play install for the IronMan bumper. I had to modify the bumper itself and grind out a fair bit of metal behind the fog location and make my own brackets to get them in there and flush. VERY happy I took the time though, I LOVE these fogs.
I use the SwitchPros SP-9100 panel for my aux lights. All of which are dimmable.
"Lighting outputs can dim from 100% to 10%, with ability to dim during Flash or Strobe patterns"
Anyone know if the 07-13 tundra kit would work on a '13 200?
An update to this and I hope it helps someone else as well. THEY DO FIT. You just need to bend the brackets a little bit (like an s-curve) and retain the factory plastic fog light bezel.
This was the kit I purchased
Anyone try the Diode Dynamics on a 2016 and newer Land Cruiser in the stock fog lamp location?
Diode dynamics Elites can be made to work on 13-15 as well with some simple brackets. And it retains the ability to set beam height precisely using the DD adjustment screw. Still working on finding my notes with the dimensions..
View attachment 3637613View attachment 3637614View attachment 3637615View attachment 3637616View attachment 3637617
Can confirm as well, I had these on my 2015 before I replaced the OEM bumper. These worked great!
Anyone find a clean option to put some BDs into the 2010 style OEM front bumper with the rectangle holes, vs the later round holes?
Thanks
