outstanding. thankyou sir.
Picked mine up today!
Almost picked up a couple extra landcruisers, but @LandCruiserPhil said no. I'll try again around my birthday.
Quick question. I haven't really looked at the switch yet, is the led always on or does it come on when the switch is turned on?
Well I have it all installed but like I said I had to make some wiring changes. I didn't go off the supplied diagram. Instead I ran off of my aux fuse block from my secondary battery. The led stays on but my disconnect switch will turn all that off. Also, I had to go to the hardware store for an extra bolt but no biggie. Lowe's is right next to a gunstore where I picked up a Ruger lcp . Win win
If the LED is staying on reversing #2 and #3 terminals will correct the light always on condition.
Best to disregard to avoid any confusion because the poster is doing a custom install.Dummy electrical question: what is this #2 and #3 terminals you speak of?
Ordered fan and disconnects.
thanks for helping me out on the phone, very, very informative!
That worked... Thanks. One thing I had to change is where you doubled up the neg wires into the terminal plug. One wire came out. I took out the ground wire and replaced it with a longer one then soldered the 2 together and added a single pigtail that I put the plug on. I didn't put the switch on the left of the steering wheel but in the bottom left of the certer dash next to the rear heat fan. I had to lengthen the wires in the front to reach the fan. Soldered them
