Auxiliary Fan Install
Picked mine up today!
Almost picked up a couple extra landcruisers, but @LandCruiserPhil said no. I'll try again around my birthday.
Quick question. I haven't really looked at the switch yet, is the led always on or does it come on when the switch is turned on?
It can work both ways. If you follow the enclosed diagram wiring the LED only comes on when the fan runs.
Well I have it all installed but like I said I had to make some wiring changes. I didn't go off the supplied diagram. Instead I ran off of my aux fuse block from my secondary battery. The led stays on but my disconnect switch will turn all that off. Also, I had to go to the hardware store for an extra bolt but no biggie. Lowe's is right next to a gunstore where I picked up a Ruger lcp . Win win
If the LED is staying on reversing #2 and #3 terminals will correct the light always on condition.
That worked... Thanks. One thing I had to change is where you doubled up the neg wires into the terminal plug. One wire came out. I took out the ground wire and replaced it with a longer one then soldered the 2 together and added a single pigtail that I put the plug on. I didn't put the switch on the left of the steering wheel but in the bottom left of the certer dash next to the rear heat fan. I had to lengthen the wires in the front to reach the fan. Soldered them
I used Aux fan from Mitsubishi Montero Sport. Initially I thought it will not fit, because of the large size, however after some trimming and new ghetto bracket fabrication it fit right on. Had to remove middle support to get it in, but reassembly was easy. Had wired for the in cabin control with the switch, work well.
Ordered fan and disconnects.
thanks for helping me out on the phone, very, very informative!
Ships today then LCP off to Mexico for more testing:grinpimp:
Shipping will resume on Wed (6-6-2018)
Switch relocation nicely done:clap:
