Another thing
Today I got quite a shock to see that there was a small puddle of green fluid on the ground about underneath the bottom radiator hose and the coolant reservoir only had about 10mm of coolant in it, so I topped it up to almost full quickly, tested the heater, and it worked, so I figured that she couldn't have lost too much coolant, so I got on my way as I had to get to an appointment.
I got home and let her cool down, and the level of the reservoir had actually increased slightly, I presume due to expansion. I tightened the bottom hose clamps; the hose-radiator clamp I think was a bit loose, so I tightened both up
Then I pulled off the radiator cap when the hoses felt soft, indicating there was no pressure in the system and the coolant level was probably 15-20mm below the neck, so I started the engine, turned on the heater and filled the radiator to the brim, and topped up the reservoir.
I then washed off the coolant I spilled and the front crossmember, steering damper etc to make any new leaks obvious.
I have a couple of questions:
1: How tight do I do up the OEM '2 wire' (for want of a better description) clamps as found on the bottom hose? Should I really crank them up until the tensioning nut feels difficult to turn?
2: Could I have done any damage with this occurrence? No bubbles evident in radiator when medium-warm (1/3 on stock gauge) engine is idling and exhaust smells typical diesel, so I presume the HG is ok? Anything else I should check? My dad said he thought it sounded more "rattly" but I don't know quite what he means by that, sometimes it sounds more rattly to me than other times. The temperature gauge never looked out of the ordinary, either high or low, for the engine running at temperature.
Look forward to people's thoughts?
