@Spike555's post (linked below) inspired me to switch my old, failing antenna with a fixed one.
So my power antenna broke again. That’s twice in 6 months. The Tundra mod was $65 in parts last time I checked and a couple hours of your time. This took me literally 10min to do. Remove the power antenna the same way if you were going to replace a broken one with a new power antenna. Then...
forum.ih8mud.com
Many people have gone the fixed Tundra antenna route, but I like the look of the short antenna and the simplicity of the install.
The kit (linked below) cost $60 via Amazon. It was delivered in less than a week from Wisconsin to Colorado.
AntennaMastsRus - Conversion Kit is Compatible with Lexus LX470 (1998-2007) - Toyota Land Cruiser (01-1998-2008)
Amazon product ASIN B07BB4KT2P
The kit did not come with instructions but it was a relatively simple project.
1) While truck is off, unscrew the cap with needle nose pliers (careful not to slip and scratch the paint
2) Turn truck to accessory and let the antenna fully extend
3) As the antenna nears the top, grab it and pull hard straight up to remove the telescoping metal and the nylon teeth strip attached to it.
This video does a great job explaining the process:
I struggled with this step initially. I was already pulling hard and the antenna would not fully eject. After getting some encouragement from other Mud members, I tried again, intent on pulling it out with what some called "a scary amount of force." Fortunately, on this attempt, the antenna and nylon strip slid right out with almost no resistance. Go figure!
