Anyone running the Icon Rebound Pro wheels?
Idaho
Website
www.youtube.com
Searching comes up with quite a few people running the standard Rebound, but is anyone running the Rebound Pro? I find these to be a very interesting take on a "bead lock". It's kind of like Method's Bead Grip, but uses hardware instead to lock the bead against the lip of the wheel.
Icon's website says they won't fit the 80 but the specs (to me) say they will.
SKU: 21817858347TT
Weight: 32 Pounds
Bolt Pattern: 6x5.5
Offset: 0mm
Backspacing: 4.750"
Bore: 106.10mm
SKU: 21817858347TT
Weight: 32 Pounds
Bolt Pattern: 6x5.5
Offset: 0mm
Backspacing: 4.750"
Bore: 106.10mm
Running them on two 80s, they certainly fit with no modification (unless they changed the design recently and didn’t tell dealers).
Edit: assuming it’s in reference to the center covers that don’t fit over the 80 hubs, which is why we have center cap spacers for Icon wheels.
Yup. No issues with fitment at all.
To pull the trigger now or wait till black Friday ??
They also just released a 16 spoke with rim guard. Not sure if they will do Toyota spacing
Which wheel is it? Totally new design? The only Pro I can find on their site (still) is the Rebound Pro. I really like the simple design of the Rebound Pro w/o the silly bolt ring, but I'm curious to see what else they have.
I am curious to see if their innerlock really works. I see it seems to work well for the exterior bead, but what about the interior? How does this compare with Method's bead grip?
Has worked great with 35s and 37s. Down to 4-5psi with no issues. Bead grip is nothing more than a tighter fit of the bead with some ridges. Innerlock is something actually in the way of the bead moving.
Both of them only apply to the outer bead.
Bumping. Anyone have pics on a rig with the 16 spoke?
cheers
