- Thread starter
- #101
Cat guard on the White Knuckle slider hangs down kind of low and looks like it would hang up on rocks. I'm thinking about cutting it off. The cat that's on there is tucked up high.
Do it!
Bummer, but absolutely understandable.Took a closer look, forgot that it ties into the frame so it stays.
Maybe could use it for broiling a roast at camp?Took a closer look, forgot that it ties into the frame so it stays.
My weird up/down idle issues on 97 LX was oxygen sensor wires damaged, under the truck. Fixed the wires and idle was fixed.Drove it 70+ miles today. It runs ok, not great but good enough on flat road. Current issues are that when cold idle is ca. 700 (this is good), but once warm idle may jump to 1200 or at times around 2000 (not good). Acceleration from a stop is sluggish, acceleration below 50 is sluggish, about 50 not up to good 1FZE standards. On the route today I had a couple of steepish hills and the 80 ran poorly up the hills, could hardly exceed 30. I towed a M416 loaded with new Geolanders for the 60 and on flat ground the trailer was unnoticeable.
I think I'm dealing with TPS issues. I have a new one on order and think that will clear up these issues.
View attachment 3949460View attachment 3949461
Had't kept up on this thread.I checked the timing and it was severely retarded so I reset. I was aiming for 7* but from a gauge the reading was 9*. Anyway the 1FZ now runs much better, good acceleration and can pull the hill.
That’s excellent to read. That’s a sweet 80/LX you saved.Finally have sorted out the poor running and idling issues with the Black Beast.
On this throttle body note that the adjustable screws have paint marks from the factory. I removed this TB from our other 80 when I did an engine swap and the adjustments on these screws should be the factory settings.
View attachment 3952581View attachment 3952582
The TB on this LX450 had one screw that I think had been jacked with and was adversely affecting the idle and preventing the idle stop from fully seating as needed. View attachment 3952588
Today I installed a new TPS to FSM spec in the factory set TB and also cleaned the ISC and reinstalled with a new o-ring.
View attachment 3952584View attachment 3952583
I then drove it on level ground and a nice hill. It was still a dog. Idle issues were corrected but it had low power, like less than 2F power, pulling the hill. I checked the timing and it was severely retarded so I reset. I was aiming for 7* but from a gauge the reading was 9*. Anyway the 1FZ now runs much better, good acceleration and can pull the hill.
