Anyone recognize this 80 (4 Viewers)
Take no prisoners!!
I use these universal joint sockets a lot for stuff like that.
Pretty sure I've had thermostats housing out without too much hassle, with exhaust shield in place
Keep the skin on your knuckles intact in the future.
I also have taken the exhaust shields off, and bolts are now generously coated in anti-sieze paste.
30 seconds would have that shield off next time its in the way.
Once I pulled off the thermostat housing neck I found a torn rubber cap inside. ???? What sort of clownage allowed this to happen? That's been rectified and leads me to wonder if the cap impeded water flowing leading to overheating and the head gasket blowing.
One of the guys at OVER THE MOUNTAIN CRUISERS - https://otmcruisers.com/ recognized the rubber cap as something that would have been in lower radiator pipe, something to cap the pipe of a new radiator to keep the innards clean until the radiator was installed. Obviously whoever did the installation was inattentive.
Shop that did the head left this sensor with a broken nipple and vac open vac line in. I had a replacement so that went in. Ran out of OEM vac line but have plenty of silicone hose from McMaster Carr.
Water bypass and PHH installed. New intake gasket hung with tab to the rear and lower intake installed. Not that bad of a job to install the lower intake.
Thought I was making good progress after having pulled the wiring harness back through the intake. But no, it should be between the 5 & 6 runners. :doh:
Had to pull the fuel rail to re-reoute the wiring harness. Haven't been this deep into a 1FZ in about 3 years so there are things that I've forgotten. Toyota's logical layout of the engine hard parts and wiring are such that if you are having difficulty reassembling, stop, step back, and take another look. Often I find that I'm doing it wrong and once I know that and see how it should fit pieces almost fall together.
The nut and bolt at the rear of the upper intake manifold are tricky as are a couple of the vac lines and hoses that need to be connected under the throttle body.
Intake manifold and throttle body back together and the half a$$ stuff that Nomad Cruisers threw on it have been corrected.
I need to find a 5/8" piece of heater hose with a 90 bend for the PHH to heater valve.
Almost back together and running. All the heavy pieces are back on. Left to do is install the battery, fill and burp the cooling system, and make a couple of brake lines. And reassemble some of the interior. That should be enough. I should stop with this. But no. Next weekend I'll be picking up a set of locked axles to throw under this thing. I need professional psychological help but I'd just ignore it.
Picked up a set of locked axles today. I don't know when I'll have time to install them. Probably not until I've been stuck a few times with open diffs. Drove N of Atlanta to get the axle and had a very brief spaitiotemporal encounter with @spazzyfry123 but not enough to make contact. @cruiserinsanity and I were at a station buying gas and he drove by in a 200.
One more item to add to the mix to make this 80 more trail capable.
Two ships passing in the night by happenchance. That QT is still an hour south of the homestead. Wouldn’t have even seen you had I not made a lap of the lot to check out the Plum Crazy 440 ‘Cuda filling up a few stalls next to you.
Beers are on me next time you make it!
Had time this afternoon to install the battery and fire it up. Battery was low and I had to jump start it but it fired up. Fired way up with the idle running 2500 rpm. Other than saying the throttle cable is not the issue (I disconnected it) I don't have any ideas. This weekend I should be able to do some troubleshooting and isolate the issue.
I ran out of time today to begin any real diagnostics.
Had the same darn thing with my wife’s 80. It ended up being a faulty tps (failed FSM tests) and a gummed up aicv. Replaced those, checked timing and she idles at 650 now. Also pulled the throttle body… again… and gave it another cleaning.
I had a spare that was working fine when it was installed on the other motor so I reused that throttle body after cleaning it. I ignored your advice to bench check, now it'll have to come back off for that. Pulling and installing the TB is not hard except for that one coolant line buried beneath it.
Yeah, that coolant line stinks. My tb was a little gummed up when I pulled it the second time (crud from the truck sitting for so many years I’d guess). Since the re-install, it’s working as it should.
At least it’s not a giant project.
View attachment 3914894View attachment 3914895
I cleaned all the contact points on the winch solenoids, cable ends, etc. and it doesn't work. So I'm going to pull the 8274 off the 40 that's not being used and throw that on in place of the Superwinch.
Pulled the throttle body today to check the TPS, it was out of adjustment. Followed the FSM in checking and adjusting the TPS and checked the ISC (I think that's correct) and it was within spec. But after reinstalling the throttle body, giving the 1FZ a jump start, the idle screamed to 4000. Something is off. I reused the TB gasket but it appeared good; had a new spare that I could not locate at the time but have since.
Stubby Vessel screwdriver was perfect for loosening and tightening the TPS screws.
Since I yanked the ABS unit and I have no idea how old the MC is on this rig I decided to replace the MC but go with a non-ABS unit (Advics AZ BMT-090). The brake booster rod had to be adjusted out ca. 1 mm (eyeball measurement). I'm having to make new lines so I'm using this opportunity to clean up the routing of the lines. More on this later as I get into it.
View attachment 3927573View attachment 3927574View attachment 3927575
I've never actually seen the PROPER tool in the wild!
I’m sorry that you’re dealing with the surging idle. It’s an absolute pain to track and diagnose. It “could” be a gummed up idle air control valve. Did you pull it?
When I pulled the one on my wife’s truck for inspection, it was gummed up something terrible. The new unit sorted it out.
