I'd really like to see a pic of the box mounting location, and see how much of the bib needs to be cut away.
TIA
TIA
Mark should know, He started the craze with the install instruction article in the Toyota Trails Mag. back in September '03.....![]()
do you just move it as close to the shock tower as possible?
Minitruck PS was barely adequate.
FJ60PS was good.
FJ60 PS w/ hydro assist is better.
There are multiple ways to attack nearly every aspect of the conversion.
Some examples- I had to trim the front clip a little, but kept the stock shock tower. Mark W. uses FJ55 parts to link the box to the column, I modified an FJ60 slip shaft and used some aftermarket parts. Some people weld a thick plate to the side of the frame and tap holes in it, others (like myself) box the frame and through-bolt the steering box to it. Some use a mix of FJ40/FJ60 draglink parts, others make custom linkage with DOM and 1 ton TRE's.
All depends on what your intended use is, what parts are available to you etc.
Install can be made to look *like* stock if so desired.
Do a little reading and post up with specific questions if you've got any.
BTW, what did you guys do with the steering stabalizer? Did you find a way to mount it off of the pitman arm, or just toss it?
I now have the Ford shock tower on order and will be working on a box mount this weekend. Is there anything crtical about where the box is positioned, or do you just move it as close to the shock tower as possible?
Any chance you have the part number for that TRE that goes in the pitman arm? I just need that and one more piece to get this thing finished.
Here are some pics of the HJ61 steering box that i used for my BJ40 ,i am still finishing everything so it will be a few more days before i knows how it drives
