Any reason not to get a radiator from autozone etc? (1 Viewer)
As a metal brass conducts better than aluminum. However in the manufacturing process brass needs to be soldered which isn't as confuctive as aluminum. So a brass radiator has the potential to be better than aluminum provided the manufacturing process is extremely good in that only the minimum amount of solder is used to still provide a sturdy piece.
In the end everyone has gone to aluminum as a brass radiator that can compete isn't cost effective.
So if you are going aftermarket go aluminum. I personally only use the Kyo aluminum rads
all parts sold through auto zone are not auto zone brand. Do as you wish but there are decent parts in the mix.
A number of aftermarket brands are available through different sources....
Interesting topics, all around. Shop around for oem it doesn't have to be brand new either, if a used oem is available you can opt for that if you are on a tight budget, right now? Pull-a-part places might have something you need or check the classifieds and get a radiator from a ih8mud member.
I wouldn't give them a single penny of my hard earned money! They cheat their employees out of their hours and business practices are not at all professional...that is why they call them vatozone!
hey im reviving this thread. I had a brass radiator fail after 4 years, less then 20k corrosion around the tank. Why autozone. Lifetime replacement. why not it may be a a piece of crap.
Will they pay for the head gasket work when you find you need to invoke the lifetime guarantee...
Obviously not, so just a cheap TYC? I spent 400 on this God damn brass one that just gave up. Why not just drop in a cheap aluminum one.
TYC is the way to go
Why not Toyota for 95-97. They retrofit.
