@Dan Higgins How many turns did you end up settling with? So far with my 2.5'' lift, I'm at about 2 turns clockwise.
I had about the same ratio (1 in 10) flashing lights at me stock brand new. I know LED lights are just bright and these are especially bright, so while yours may be actually hitting people with your lift, I know people flash even if they're not. I find myself mistaking brights for low beam LEDs, too.
I recently ran into this issue when installing a 2" lift on my 2016. The outer bolts are for the vertical adjustment and inner bolts are horizontal adjustment. Do not turn them too much or you will have to pull the headlight out to reset the adjustment screw. It should only take a full turn or so to get the headlights low enough to keep from blinding traffic in front of you.
I simply parked in front of the garage and adjusted until the cut off line was an inch or so lower than what it was before. You can either make very small turns by sticking a flat head screw driver in the access holes by the diagrams of what to adjust or you could put a small socket on the adjuster you are turning and adjust there.
forum.ih8mud.com
Thank you. This thread was helpful for aiming my headlights. Once I had the horizontal plane at the centerline of my lights marked with a laser level, it was a 10 minute job.I'm having a hard time keeping vulgarities out of my responses to these issues:
1) headlights break if adjusted beyond an unobvious threshold, and repair costs $2,000 per fixture to replace
2) inadequate warnings in the manual
3) inadequately trained service reps
the list could go on..
Here's my thread on pretty much the same issue fwiw.
Stock 2016 LC, My high beams actually suck IMO
forum.ih8mud.com
Thanks, I used the laser level method too (25ft distance) - but after 10 full turns I’m still about 2 inches above the laser level. Either prelift they were way too high or it needs another 10 turns which seems excessive.Paying the dealer is a risk mitigation strategy.
Then again, I did it for free in my garage after my lift. I used a laser level to find the level of the headlights on the wall, marked it on pieces of painters tape on the garage door, using the factory service manual distance from the door, I turned the screws until they were the specified distance below the level line.
I think where people get into trouble is when they just try to wing it and over adjust causing the adjusting screw to come out of the threaded portion. It didn't take much adjustment to realign them to spec.
after my lift install i need to do this. Should have thought to have the dealer do it, but of course I didn't. The dial my tundra had would be nice right now.Paying the dealer is a risk mitigation strategy.
Have you installed the rear suspension height sensor adjustable link? Get that dialed in and the headlights should be a minimal adjustment.So I definitely need to aim my headlights, they're too high after I installed my bilstein 6112/5160's. Read the factory bit, this seems really straight forward. I'm a little taken aback that you can adjust the projectors to such a point where they fall apart. There's no stop on the adjuster? Any advice as to "Hey, don't turn the adjuster more than 10 turns or 15 turns etc?"
