2008 landcruiser wheel offset +20 18 or +1-12 on 17x8.5? Any issues?
canada
Hey guys, any advice would be appreciated I’m looking at doing a set of fuel or black rhino wheels but it’s tough to find any wheels with a higher offset close to factory. Do you think going low will be too aggressive without a lift ?
It depends on your tire size to achieve ideal scrub radius but a +25 to +35 offset is perfect for the bigger tire sizes. It will still tuck under fender but enough clearance for UCA and body mounts etc.
If you run a large enough tire you will likely have issues with the tire rubbing the top of the fender when stuffed. I am on +35mm and my 285/80R17's(really they are narrow 315/70's) get mighty close to the fenders when slightly turned. If I remove the bump stops they do rub.
