- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,205
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Is the Rancho a universal fit?
It's for a different application, will confirm and post the numbers.
@Tools R Us my rancho came with hardware that looks the same as the P01034. As I was bolting it up, the tapered end that goes thru the tie rod end mounting hole would not go that far. I could thread the castle nut for only about 4-5 turns and thats it. It calls for 35 ft lbs. I think it would torque but would only hold a couple of threads. Is this how you guys are installing it or i need a different mounting kit.The mount pins are pretty common, we had some laying around from replacing OME units. If needed the Rancho/Monroe P01034 hardware kit is the one needed.
@Tools R Us my rancho came with hardware that looks the same as the P01034. ...
I found the plastic the hardware came with. It says P-837. Wrong hardware I suppose. Is the P01034 supposed to be supplied or its something you buy additionally?
The one carid sent me is stamped rs5404 on the shock.That would depend on the stabilizer that you bought?
carid....![]()
IIRC, that is the number that I have. Compared to a stock one, it's ~2" short and a little short on stroke. Had to flip the frame end bracket, put it on with a bolt and sleeve in the bushing, still lost turn, it's short on stroke. It's normally for a domestic application, don't recall any of the hardware being correct for the '80.
Depending on how the rig is used, the Monroe SC2957 units have worked well, at the price (~$25) not a bad way to get the hardware?
Thanks tools. I thought it would be plug and play like the ome ones. Are the monroe sc2957s plug n play or needs to be modified to work?
Thank you so much. I'll try that out.Plug and play, bolts on the same way as the OME.
My truck has an OME that is way over 12 years old and still working. S for benefits, I had run the truck without one and I have not noted any difference.
Trying to revamp my steering. Who else is running the cheapo Monroe stabilizer you can get on amazon?
Thoughts? Opinions? The OME/Dobinsons equivalent is about 3x the cost, struggling to understand how they would provide any additional benefit.
Because I have two trucks, one with OME, the other with factory stabilizer, both been on/off road.How do you know it’s still working if there is no difference?
