Wow, didn't realize it was so labor intensive, must be buried. Thanks for info
Fwiw, I highly recommend folks learn to jump the starter in the event it fails in the same mode most do.
If you lay under the truck and look up at the passenger side of the engine you can see the starter.Ok cruiser experts, need help here. I was able to "Jumper" my old starter by connecting two leads of jumper cables to a long screwdriver touching the braided copper wire from the solenoid to the starter. it took a couple trys, but finally worked. If you are in a jam and get the dreaded starter,"Click" remove the heat shield and have someone push the starter button. when you hear the relay energize, clamp the jumpercable to the screwdriver and you can start the truck.
I purchased a rebuilt starter from Autozone ($155 vs dealer 356), worked on and off over the holiday weekend, probably 8 hrs total at a leisurely pace. replaced the starter. went for test drive, started a couple times no problem.
This morning go out to the truck to go to work.....no start. Dash goes dark, click, no turn over. Did check OBD codes, P335,340, 345,365,390
crank position sensor, cam position sensor, fuel...computer is not happy...
held test leads on battery while the Mrs. pushed the starter button. batter only dropped to 11.65v
my fear is bad starter from "the zone" cause it was a beeeeyotch to replace.
does anyone know of any other relay, fuse, or electrical connection that may be causing this?
Tundra forums mention a starter relay.
Duralast Relay - Starter 20282
at $70 and questionable avialability, would like to get some feedback or experience on this issue.
@bjowett have any input on new bad starter or other causes?
thanks
Given the location of the starter near the manifold, anyone thought about installing a starter heat blanket? I would think heat is a contributing factor to failures.
Wonder if it could be installed easily with the starter installed.
Free Shipping on Orders Over $109 at Summit Racing
Get fast, Free Standard Shipping on orders over Summit Racing Equipment from $109 -- no shipping, handling, or rural fees! Exclusions apply.www.summitracing.com
Could someone post the p/n’s for the exhaust gaskets and nuts that should be replaced during this job?
@bloc
Hence the phrase in my post “I’ll google it and search as well”
keyboard warriors are on mud all the time apparently.
