Builds Another FJ68 Build
I have a slinky, icon 3" lift ordered. Also got a front ARB locker. Picked up some slee caster correction plates. The tranny is rebuilt and the circle D torque converter came in. Now just trying to figure out the fuel tank. Looks like a custom stainless or aluminum tabk with the stock fuel pump carterage. I have been keeping a pretty accurate spreadsheet of everything I havr bought. I figure I will have close to 30k when all said and done.
Curious about the icon lift you ordered..
slinky? Is that the same one its been talked about on the 80'$ forum?
Megolfer,
Question... The picture of the oil filter and canister, where does that mount and what's it for?
Thanks, very exciting build.
Looking good! That is the best spot to cut and shorten the frame in my opinion. Doing the same on my chassis swap. Are you using a 110v machine? Kind of looks like it by the welds. I have got both, 110v and 230v and even with both on the same setting the 230v lays down such a nicer more beautiful bead, much easier to use too.
Anyways, subscribed! :)
Cheers
Drivetrain is mounted.
Wow that TC is tucked away... Nice...!!
Are going to run a lift?
Epic.
What yah doing for Castor angles?
Wow! Just seeing this build for the first time and I really dig what's happening here.
Question: this is the second build (RMPO's being the other) where the 80 frame is being cut right where this rear bracket has to be removed and re installed...
What's the advantage of doing this? Seems like doing it like Project X2 or Manu style saves this extra step. Just wondering...
I've always liked those FJ rims you got and have been considering some for my truck in the future. Would love to see them mounted up.
Keep it coming!
-Ed
