Build Another FJ68 Build
Member Build Threads
Hopefully it os worth it.
I have heard nothing but great things about it....
I thought about getting it, but I'm afraid my rear is too heavy, and this lift won't do the trick... I'm happy with the slee's on the rear, but not the fronts.....
Let me know how you like it as it look like your set up is the only one that i could compare mine to.......
:beer::beer::beer:
Got the tank done
^^^ Nicely done...!!!
Your pass floor will be nice and toasty on the winters, but a tad hot on the summers...
Great job on routing that exhaust in front of the T/C.
who did your tank?
I like it....!!!
Stainless steel? Aluminum?
The hank is aluminum. Local shop made it up. There is a skid under the tank to protect it. The gm caterage will fit in it. The cat is extremely tight on the passenget side. Next I need to finish up the bumpers, sliders and any tabs on the frame then pull the body and clean and paint everything. Still a lot of work.
How did you mount your tank? To the frame or body? I like that skidplate, I will have to do something similar because I'm going to try and fit a big tank back there as well.
you had a drain out installed on that tank, right? What shop did the work and how badly did it hurt?
