www.jkcustoms.com There ya go so go and get you one!!
Thanks vipergrhd, I have found one issue that was the problem with the tranny. The AA 6-4 bolt adapter/VSS combo allows the VSS to pick up the relunctor ring signal off the shaft. Well if there is play in the shaft and the gap opens up on the VSS, the truck thinks it goes from 62 to 25 in a split second. Not good for the tranny that thinks it needs to shift. That is what caused my problem. To solve it I am putting on a Downey transfer case VSS adapter.OF which I know works!! Thank god for Downey!!! So Scott will be able to pick up his truck on schedule.
TRANNY SHIFT ISSUE FIXED![]()
