So now it’s officially summer and hotter than the hinges of hell here in Texas. I’ve been daily driving the 61 without AC. I finally collected all the parts and started reassembling the cooling system.
The trucks original condenser was crusty and literally falling apart. The HJ61 condenser is of course NLA from Toyota. I’ve been searching the globe for a replacement for months but I think I finally have a solution.
The readily available FJ60 condenser is a near match except at the inlet elbow points off at about 2 o’clock instead of 12 o’clock on the 61. The outlet adapter can be swapped over because the outlet elbow and fittings are the same. The isolator mounts are different between 60 and 61, but five minutes with a grinder will turn the 60 style into the 61 style.
View attachment 2705685View attachment 2705686
I found an awesome old-school A/C shop here in Austin, and dropped off my condenser yesterday. They told me they will be able to braze and pressure test it and it should be done by tomorrow.
60 on top, 61 at bottom. 61 inlet (on the right) needs to point very nearly vertical because of the quad headlights and the location of the compressor.
