I have a old Man-a-fre hi performance alternator bolted on my 77 2f. It puts out about 90 amps. I want to beef up the wiring a little bit since I run a winch. One thing I did was delete the amp gauge and am installing a volt gauge instead. From what I understand I just run a heavy duty wire from the b+ on the alternator to the battery positive. Sound right? Instead of using a fusible link I was thinking of using a 120 amp circuit breaker. I was going to put it in line between the the b+ and batt+ cable. That sound ok? Where does the factory fusible link run? I don't recall seeing one on my harness.
