- Joined
- Jul 8, 2004
- Threads
- 111
- Messages
- 1,357
If it fits a '76 I would be interested in one as well
It would work as is for 24V, but I'll make some changes to better protect the circuit from voltage spikes . The voltage limit of the circuit now is 30V but a transient spike above 30V could destroy the voltage regulator (VR). The only difference in a 24V truck is that the VR is converting an additional 12V into heat.Amazing work. Now can you please please make one for us 24V guys up here in canada, where I live the rain is always here
I think the Matsuba is fine as long as you don't mind the non-OEM knob. I think the adapter Coolerman was making ended up being a little more complex than he originally hoped?Be very glad you don't live anywhere near me - I'd either keep you buried in projects or just drive you nuts . I love that custom designed stuff that is fully tested and proven - becoming a rarity it seems or at least what is available to fabricators unless you go big .
Very interesting work , even if I only understand about 20% of it , lol .
So , I bought and Matsuba controller for nothing ??
I'm using the original switch. I realize I didn't really explain how the module works despite the long post. The uC monitors the position of the switch and switches the relays as required. There is no longer 12V in the switch, but there is 3.3V that the uC can monitor. Nothing changes in the truck. You unplug the switch from the harness and plug the module inline. I'm not sure what a dragging motor/linkage is, but it should have no effect. The module is simply switching grounds for the lo and hi speed wires.I assume from reading you are building or built an inline logic controller with a different than OEM switch?
Did you test it with a badly dragging motor/linkage ? That is the most common issue with older trucks , especially Cruisers ...
Sarge
I do try to be methodical. 25 years in Naval aviation can do that to a person. Vibration would only affect the uC that is in a socket. It could conceivably work loose, but it could be soldered to the board instead. I'll give that some thought. It's not waterproof but I would consider it very water resistant if the wire entry/exit openings were sealed. It could also be "potted" but I've never tried that before. Don't know what costs are involved.This is amazing! As a pilot I love technical details and your approach to solving a problem is very methodical. Well done!
How resistant to vibrations are the uC's and other associated non-solid state components? Any ideas about preventing water and dust intrusion?
I'm in for a couple...
I really don't know. Not trying to be evasive, I just haven't finalized the design or compiled a final bill of materials yet. I haven't even priced the harness connectors or wire either. I'll start figuring it out soon enough.I'd be in for one. Assuming you start producing these, what are you thinking for a price?
I designed it for Coolerman's '71 and tested it on my '78. It should work on any year in between as well as later years. Not sure about earlier than '68.If it fits a '76 I would be interested in one as well
The relays are 15 amp. The harness wiring for the wipers and washer (in my '78 at least) are 18 AWG (hence the 15A fuse for that circuit). I wouldn't want more than ~7A on stranded 18AWG wire....I would think if the relay is rated to handle 30 amps it shouldn't have a problem as long as the wiring coming in/out can support the load.
Sarge
Good question. Of course, any polarized cap is sensitive to reverse polarity and all of the components are sensitive to voltage (and current) spikes. Tantalum caps can fail (badly compared to an aluminum cap) if used improperly. TI recommends that cap for the voltage regulator in the prototype, but I will probably use a different automotive-grade VR and a low-ESR Al cap.I've read that tantalum capacitors are sensitive to voltage spikes and reverse polarity, and can fail catastrophically. How are these considerations addressed in the design?
