ALL US Landcruiser/LX service manuals 1960-2018 (all years all models)
Does someone have something like this for how to view OFFLINE on android/iOS mobile devices?
While I am at it, here is the full tutorial on how to get the current LC70 service manual running on any Android smartphone or tablet. All other HTML based service manuals will work too, it follows the same principle.
Here we go, let me know if something is unclear:
1)
Install f-droid client App: Visit F-Droid - Free and Open Source Android App Repository - https://f-droid.org and click "Download F-Droid". Then install the APK.
2)
Open the F-Droid App and search for the App "Termux" Terminal Emulator App. Install it within F-Droid.
3)
Open the Termux App and first of all start an update/upgrade with the command:
Bash:
pkg upgrade
Agree with "y" + Enter key. Wait for updates to finish. If asked for to overwrite configuration files always anser "y" for yes.
4)
Install nginx web server and git with this command:
Bash:
pkg install nginx git
5)
In termux empty the nginx web root folder with this command:
Bash:
rm -rfv ../usr/share/nginx/html/*
6)
Copy the service manual to the nginx web root folder. There is different ways to achieve that.
6A)
Here is one way:
Clone the repository contents into the web root folder by issuing this command:
Bash:
git clone https://github.com/randokuruza70/manual ../usr/share/nginx/html
6B)
Another way would be:
Download one of the service manuals as ZIP file, i.e. by issuing this command for the current 70 series service manual:
Bash:
wget https://github.com/randokuruza70/manual/archive/refs/heads/main.zip
If you downloaded the ZIP file via browser to your device to another folder than the Termux user folder, please move the ZIP file from you Android Downloads folder to the Termux user folder. There is many ways to do this, here is an easy one: Open the Files App, choose the ZIP file and move it to the Termux folder by clicking the burger icon top left, then scroll down the list and choose "Termux". This will bring you into the Termux user folder. Move the ZIP file into that folder.
Then unzip the ZIP file into the nginx web root folder by issuing this command:
Bash:
unzip main.zip -d ../usr/share/nginx/html
7)
Add a certain mime type configuration parameter to be able to display the interactive electrical diagrams, by issuing this command:
Bash:
sed -i -e 's/xml;/xml xsl;/g' ../usr/etc/nginx/mime.types
8)
Start nginx web server by typing "nginx" + Enter
9)
Leave Termux running in the background and open the web browser on your phone and point to this URL:
(Depending on the manual you may need to specify a subfolder or file, i.e. "http://localhost:8080/pgm/top.html")
10)
Whenever you stop the Termux App or reboot your phone you just need to start nginx web server again with step 8).
That's about it, here you are now, able to read the service manual from the field offline with any Android device you want!
Hint:
Sometimes, if you update nginx within Termux (pkg upgrade) the index.html file in the web root folder may be overwritten by the update process. In that case and if you went with Option 6A) of this tutorial just issue this command within Termux:
Bash:
cd ../usr/share/nginx/html && git pull
If you went with Option 6B) you may just take the index.html from the original ZIP archive and use it to replace the index.html file from the update process.
1)
2)
3)
Bash:
pkg upgrade
4)
Bash:
5)
Bash:
6)
6A)
Here is one way:
Bash:
6B)
Bash:
Bash:
7)
Bash:
8)
9)
10)
Hint:
Bash:
Thank you so much.
I apologise if my questions are basic, I'm not as tech savvy.
What should I use for 100 series (or other models) for step 6A? I changed the 70 to 100 and it did not work.
I used 6B and the link to zip files in https://toyotamanuals.gitlab.io/toyotamanuals/ as
Bash:
wget https://gitlab.com/ToyotaManuals/pz471-z0020-ca/-/archive/main/pz471-z0020-ca-main.zip
On running the or I get a 404 error.
My top.html file is located at "/data/data/com.termux/files/usr/share/nginx/html/top.html"
Code:
should be correct. Go with 6B)
Step 6A) via git would not work in that case I guess.
Check that the content of the html folder is all the files from the ZIP Archive. Sometimes when unpacking the content is extracted in the html folder into a newly created subfolder. This we do not want.
try: http://localhost:8080, next try http://localhost:8080/htmlweb/contents/index3.html
Code:
Thanks. Now I have a 403 error on the first link and 404 on the second
Check the error log file content. You will find the log file(s) in the folder "logs" in the nginx folder.
Is there any chance the 80 series books have been digested yet? I am looking for information on how to service my transmission. Thank you!
1993 HDJ81
@DivByZero Any chance you can post up the Mega download link again? Says the file is no longer available for download.
THIS IS AMAZING! Thank you so much :)
I've just done a major update at https://toyotamanuals.gitlab.io/toyotamanuals. You'll now find hosted ALL digital manuals for ALL Toyota vehicles which have ever been made available in Australia, I believe Europe/South America, and a lot of them from North America too.
This took a lot of time, work, and money. I had to write custom software to mirror all the manual content, most of it behind subscription paywalls. Then the manuals themselves are generally broken. There are several "generations" of web-based systems here, and all but the latest version is completely broken on anything but a 1999 era version of Internet Explorer. Even if you pay money for a subscription, or manage to buy/acquire a CD for the manuals, it'd still be broken. Well, was broken. I wrote software to update all the scripting to be compatible with a modern browser. Only tested on Google Chrome, but should be ok on other things. This was non-trivial and very time consuming, as some of these systems were very complex. It makes the manuals fully accessible now though, and there are some very, very cool features on some of these digital manuals. Check out the "XmlWeb" versions, like this 200 Series LandCruiser Manual. The interactive wiring diagrams in particular are very slick.
All the manuals are now hosted online, with full functionality, so you can browse them without downloading anything. This took a bit of work too, as some of the larger manuals are pretty big, and there's a 1GB limit for hosted sites on GitLab which I'm using to put these online. Where the manuals run out of space, the hosted versions downsample the image quality to make it fit. This keeps it available online for everyone, with a slight reduction in quality.
Every manual can be downloaded too, and you'll find a download link next to every manual on the webpage. This'll give you a zip file. Just extract it, and then execute the "RunLocal.cmd" file. On Windows, this will automatically host the website on a local webserver, and launch your web browser to view it. This will give you a faster, smoother experience than the online hosted versions, without any loss of image quality, and you'll have your own copy forever in case this gets nuked off the internet.
In terms of LandCruiser manuals, this site has all the content for the 70, 100, 120, 150, 200, and 300 series. What's missing is the stuff that Toyota never ever digitized, which is the 80 series and earlier non-US manuals, the 90 series prado, and some of the very early 70 series stuff. A lot of that is already out there in some form or other, and I'll eventually put it up on the site too. And as for what's not available online at all right now, that's where this comes in:
That's a future project, but I'd like to scan everything here that's not out there already. I have (in one form or another), all chassis manuals and wiring diagrams for the 70, 80, and 90 series, as well as extras like new car feature manuals, transmission manuals, engine manuals, etc. And the same for the 5th generation Hilux and 2nd generation 4Runner.
Anyway, enjoy.
@DivByZero
It’s huge, thank you so much!
Could you please reupload Prado 2021 manual? At least there is /N00237/manual/repair/contents/flow/ folder content missing so Repair manual is only partly working.
Anyway, enjoy.
much much appreciated. Thanks a bunch!!
What a legend! DivByZero, this resource is a godsend. Did you ever get around to uploading the 90 series prado? I can access your toyotamanuals site, but it looks like the mega links are dead. The 90 series isn't listed unless it's included in one of the other models.
As for older landcruiser manuals, I've obtained a few more things in recent months, including most of the manuals for the 90 series landcruiser prado, and new car feature info for the 80 and 90 series. I'll get it all scanned when I can. The unscanned 80 series wiring diagrams will be first up.
Sorry to anyone who's already downloaded/started downloading this, but I just did an integrity check and discovered a few data errors crept in when I transferred this from my source. I've corrected the errors. I've removed the mega.nz complete image, because I'll need time to reupload it, but I've replaced the torrent with a fixed version and you can download through that right now. This is the link for the updated torrent (will also be updated above):
I'll re-upload a complete image sometime in the next day or two. EDIT: The complete archive is back up, link in the first post.
By way of apology, here's a few other interesting links:
Toyota EPC 2021-05 - 6.8 GB file on MEGA - https://mega.nz/file/1AcnVQTD#BK3vkeer01y7Fi88nIxWdXQEgrlfjgD15xmbBgcmTEI
Toyota EPC 2021-05 torrent - 137.2 KB file on MEGA - https://mega.nz/file/QEswhaQD#oX2M6_Y2But7fugkN5EMrdvwmLqB6enTcB8EwTVQ2KM
Toyota Techstream 16.20.023 - 974.91 MB file on MEGA - https://mega.nz/file/Jh4CTTYL#KPKbWCT_kWh38EXyecGStNYiIE3ucCdrZErGJGYzHo4
I downloaded all of the files from month ago and you are right all the links not working now. I think all file in MEGA not working now and you can use another way to sharing. thank you for sharing files and you are doing a great job with all huge size of files you sharing with us I hope you'll find a way to make the links working again for the members want to download it
Just read up to the lastest this incredible thread. Checked out the website and did not see anything before 80 Series. Any chance 60 Series resources are in the mix at some point?
Thank you so much.
This might be a simpleton question but where are the 60 Series manuals?
I think you have to offer this amazing volunteer to help him with digitalizing this one :)
Good luck!
More than happy to help. Which manuals can I start scanning in?
