What about the longer spring is making it tight ?I had a local rock crawler builder/fabricator tell me that was a mistake to have them built that way - but, it does ride well.
I doubt it. Cruisers are notorious for their driver side lean. So much so that one of Man-A-Fre’s fixes back in the day was a 3/4” lowering block for the “offending high side”, which to me is just... just....@RUSH55 They are stock wheels widened. Do you know, were stock springs arched a little higher on the drivers side to compensate for the lean?
It was just more difficult to get the shackles aligned when installing because the spring is longer. Not sure how to explain, there is always tension on a shackle but it seems there is more pressure on it than a standard set of springs at resting state. Not sure if that is making any sense. I could be totally mistaken. I'm not a suspension specialist by any stretch. I do know it rides real nice though.What about the longer spring is making it tight ?
OK now I’m understanding your 1” longer statement and that would make more sense why your shackles look a little forward of where they should be.So they are longer for the lift, and then longer again
I have Alcans on mine. It rides really nice with the OME shocks. I had them built for 3" lift spring under. I did not have them built for extra weight other than a winch up front. Can't really see in this pic, but it usually has some rake to it, so we'll see if it settles once I add a little weight. It rides really nice, though I did add a sway bar after the lift which improved things quite a bit.
Someone on the forum suggested having the spring 1" longer on the shackle side which I did. I think that was a mistake and I may be getting a replacement main leaf from Alcan. The shackles just seem to tight. I have 1 1/2" extended shackles and they barely fit. Stock shackles could not be installed because they would not reach the eye of the spring. Also my truck didn't lean before the lift, now it does. I don't know what it causing it, but I wonder if it has something to do with those tight longer springs? I had a local rock crawler builder/fabricator tell me that was a mistake to have them built that way - but, it does ride well.
I did have to send my springs back for a little fine tuning. Sucks living in the boonies sometimes, but Alcan is 12 hrs away and I couldn't find a shop close that had a lot of experience with 4x4 springs like Alcan does. I've heard a lot of mixed reviews on Alcan, but the ride on my 55 is great. Rides really smooth and I would say very comparable maybe even better than my 60 with OME lift. Alcan is currently building a set of springs for another cruiser of mine.
I have a 1 cruiser on blocks at a time rule.
@J Mack @RUSH55
makes me think something it binding. I guess in theory if I remove the shocks and see where it sits I could rule out them as the issue.
Agree looks great in that picture!Those shackle angles look great.
