Builds AK HJ-75 (1 Viewer)
Decided to prep the back wall for the same treatment
The Spectrum is over the dampening sheets... what is the total thickness?
Spectrum is sold plain or you can buy it with an additional thickness modifier. Spectrum™ Sludge Deadener - https://www.secondskinaudio.com/sound-deadening/spectrum-sludge
They talk about 1mm thickness per coat with the sludge and from my experience that seems about right. If you do try any of the sludge I would recommend you mix it a bit thinner than they recommend and only mix a little at a time. Of course I was using it in very low humidity and pretty warm temps so maybe it's not so bad about setting up quickly in more favorable climates.
I used two or three layers of the sludge to fill in all the voids on and around the Damplifier Pro and then put a couple of coats of plain Spectrum over everything to smooth out the surface. My intention was to try to replicate the factory look. I still need to topcoat it but will do that when I get the truck back to the US.
Today started putting the dash/HVAC back together after playing with the Second Skin Luxury Liner Pro. First place to put it on was on the passenger side firewall. I used some of the metal tabs that were used to secure the factory firewall liner. Might not paint the floor or back wall if I can get this stuff to stay put using some double sided foam tape.
