- Thread starter
- #101
I'm ashamed to say I probably went 5k since the last oil change....I never let it get low though but I guess when the cooling functionality goes away that doesn't much matter. Live and learn!
Yeah that is a pretty convoluted thread, but the confusion comes from where Toyota calls a powdered metal rod a "sintered and forged" it is neither cast nor forged. Cast is poured into a mold, forged is a solid block pressed under extreme heat and pressure. Toyota has used powdered metal pressed like a forging. Using powdered metal means less waste, but also much less strength than a true forged rod.
I have had rods from a 2UZ in LC and Tundra as well as 1UZ from SC400 and 3UZ from LS430 and they are all powdered metal rods. In Toyota speak "sintered and forged" but not forged or cast.
I'm not sure of the connection between your insomnia and this failure? This doesn't "appear" to be driven by a TB failure, no?Thanks for giving me insomnia now. I haven't done a TB change yet (190,000 miles so far) and since I had a 1998 pre-vvti I assumed, non interference and thought I could get away with it till I hit 200,000. Now I'm second guessing that gamble. I suppose when I do the TB, I'll replace pulleys and tensioners too. Sheesh. So sorry. You're a good sport about it though.
What was the oil level in the motor when it died?
Why would you not change your timing belt? You risk being stranded, having to pay a massive tow bill, and paying for TB on top of that. Part of responsible ownership of a vehicle is maintaining it, driving anything until it fails is always more expensive than properly maintaining a vehicle.Thanks for giving me insomnia now. I haven't done a TB change yet (190,000 miles so far) and since I had a 1998 pre-vvti I assumed, non interference and thought I could get away with it till I hit 200,000. Now I'm second guessing that gamble. I suppose when I do the TB, I'll replace pulleys and tensioners too. Sheesh. So sorry. You're a good sport about it though.
Oil was full. Changed within 5k but the mech said it was black and gooey coming out if the oil pan.
