I have run Firestone airbags inside my stock LX rear coils for the last 25K miles without a problem.
I have now switched to OME 861/862 coils and the diameter of the spring steel is thicker than the stock coils. With the stock coils the deflated air bags floated freely inside the coils. When I swapped the bags over to the new OME coils they are very tight inside the coils even when deflated.
My question is if it is OK for an unloaded air bag to be "jammed" inside a coil or should it float freely within the coil through the travel of an unloaded suspension. My challenge is that the bag is now moving with the spring and stressing the air fitting connection on the bag and causing it to leak.
One thought is that the bags have stretched over time to the point that even a deflated bag is still of larger diameter than when it was new. I normally run 10 psi in the bags and occasionally bump it up to 25 psi for a trailer with 450lb tongue weight.
Thoughts?
Thoughts?
