AHC pump out? With code 1762 (2 Viewers)
Note the V1.x cables will not allow you to write data to the car. V2.x cables will. That is important for key programming, TPMS, some of the customization features and other stuff. All the cables should support what you need to read data. I had a 1.x cable and had to buy a second cable with 2.x firmware to ensure I could update my TPMS (after the tire shop was unable to).
I have seen 1.x was able to program key, customize telescoping, door lock, window and sunroof settings.
  • Like
Reactions: MJK
The 1.x cable I own was able to program my key, disable my DRLs, and stop that annoying auto-telescope wheel from activating. I have a 01LX that doesn't have TPMS, and I have read multiple places that the V1.x cables don't allow TPMS manipulation.
I think for SURE the 200 series would benefit from the V2.x cable. On the Hundys, it is perhaps only a benefit for those folks with TPMS and maybe some more advanced key programming requirements?
  • Like
Reactions: MJK
Same here. You can also manually provide switch inputs in Techstream with my version 1.X cable (example: mirror controls).
No TPMS on my 05 either (thank God).
@BullElk
Was reading the thread @ramangain provided along with your new info. When does your cable get here?
If you have never adjusted tbars on this rig, it sounds like the pressure may have finally gotten high enough that AHC self protected to low only. Does this one have extra weight on it too? I'd be tempted to give the tbars at least a few turns now just to see if I could relieve enough pressure just to get out of self protection mode.
A couple years ago I gave the TBs a few turns, not exactly sure how many and a day or so ago I gave them two turns.
Now when I start truck the motor doesn’t even run at all on its on It does when apply direct power from battery in video below.
I checked the pressure sensor as per a thread from another forum. Said to unplug sensor and start vehicle. If it raises then the sensor is bad. It didn’t raise so I guess that may rule out the sensor.
Oh boy that motor sounds .... unhealthy
Edit: the tone sounds right, just loud. Is there any actual fluid in the pump?
You can also try loosening a fitting on a globe or the tube accumulator and operating the AHC. Without pressure if the motor can't push fluid it is for sure shot.
  • Like
Reactions: MJK
Ouch - that crunchy sound is concerning.
I think I'd park that in the 'work bay' pending the arrival of Techsteam, a pump and a shedload of fluid.
I ask because when I accidentally ran my pump dry when doing an AHC fluid flush as an AHC novice, it sounded very similar.
I guess it costs you nothing to use a turkey baster to get the fluid out of the reservoir to save, remove the hose and plug that leaves the AHC pump, then remove the pump + motor to inspect. If your AHC fluid is anything but pink, get yourself 3-4 bottles of AHC fluid from your local dealership.
Yea I plan to buy or order some fluid tomorrow. Wouldn’t I need to relieve fluid pressure at a globe before disconnecting line from pump?
Yes, I'd plan on cracking open a globe valve on each side and letting it hit the bump stops. Your CVs will thank you for not driving it while you fix this issue.
The happy marriage of a working pump, fresh fluid, and Techstream will hopefully get you back in working order.
There are also instructions on pump diagnosis and replacement in the archives, probably.
AND, while the truck is idle, you can baseline it all over again!
It's surely gonna sit tight. And I can't wait to sink some baselining into it. :)
The video sound indicates an unhappy pump. The cause of unhappiness is far from clear. However, it did not sound fatal to me and may or may not be the pump itself. For example, a downstream blockage may be preventing or limiting discharge volume and this would result in the rising pitch of the sound of pump as it builds up pressure until it switches itself off due to overpressure or other self-protection. This may result in the Height Control Accumulator not being recharged, hindering raising of the vehicle. Or there may be problems in the Control Valve Assembly or the Pump Attenuator or the Pressure Sensor or even the AHC Electronic Control Unit (ECU) itself. Checking the electrical condition of the Pressure Sensor is done very easily with a multi-metre – see Factory Service Manual (FSM) references further below. I suspect that the Pressure Sensor is working and this is what is preventing pump operation for self-protection -- but it is better to check it properly.
The pump is a simple robust positive-displacement gear pump. Diagrams of the pump and other AHC components can be found in the FSM at the pathway given below.
You are giving yourself a very hard time without a scanning tool to do some basic diagnostics and also identify the Diagnostic Trouble Codes (DTC’s) which will be present in this situation. It also means that all that we onlookers can do is offer wild best guesses with insufficient information – as I have done above.
If you are not confident about getting Techstream to work or if it takes too long to get the required cable, then may I suggest going to an auto store and buy a cheap Bluetooth dongle which plugs into the DLC3 diagnostic below the dash next to the brake pedal, then download and use the app described at this link:
AHC rough ride, with readouts from ecu
This arrangement is not as capable as Techstream but it is simple and it will get you to the AHC Electronic Control Unit (ECU) on a plug-and-play basis.
Then you may be able see whatever DTC’s are listed and also see what, if any, pressure readings can be obtained. Note that AHC pressure readings depend on being able to drop the vehicle down to “LO” and then raise back to “N” – which currently you are unable to do because the vehicle will not raise -- but you may see something.
You also do need to look at the relevant parts of the Factory Service Manual (FSM).
To do this, go to https://lc100e.github.io/manual/ . To start, find your way to AHC general description and diagrams by following the tabs along the pathway depicted below. Diagrams of AHC components and an explanation of how they work are found here:
Next, follow another pathway to the “Problems Symptoms Table” as shown below. This lists various symptoms and gives a lead as to the possible causes. As stated at the top of this Table, it is best to work through these methodically in the order given in the table, rather than start in the middle with a guess.
Details of all of the Diagnostic Trouble Codes also are found in this section of the FSM, as well as details on how to check the Pressure Sensor on the AHC Pump with a multi-meter (without removing the Sensor).
The “Repair Manual” section of the FSM also explains how to go about removal of various items. In this section, scroll all the way down until you reach the "Active Height Control" sections.
As @ramangain already suggested, if you are inclined to remove and dismantle the AHC Pump (not difficult), this will first require depressurising the AHC system by very gently carefully opening the bleeder valves and catching the fluid with a hose leading to a container. Be very aware that the stored pressure is quite high and the vehicle will drop suddenly to the bump stops. As @ramangain noted, this also would provide an opportunity to open the bleeder at the Height Control Accumulator (long black cylinder on Left side chassis rail) and briefly start the pump again and observe whether fluid is being pumped, or not. Releasing fluid from all four ‘globes’ also would give you a good idea of the condition of the existing AHC fluid.
The attached Technical Service Bulletin (TSB) may be helpful, although it mainly applies to older vehicles.
Anyway, always happy to try to help -- please keep us all posted.
  • AHC TSB for Diagnosis & Repair Procedure of AHC Pump Sub-Assembly_CP3006_1_1 (6).pdf
@BullElk I think you might be doing more damage than anything. I would not do anything at all until you get Techstream hooked up.
That pump sounded to me like a functional pump (albeit loud) that ran until it fully pressurized it's output and then groaned as it tried to pump against a saturated output. In normal circumstances, I think the computer(s) would stop the pump the instant that happens. That's how you kill pumps, rupture seals, lines, etc...
Fluid flush and Techstream data should be telling.
I got the Techstream today. Holy chinese Toledo this thing looks sketchy. Directions, box, and says to disable firewall and antivirus software. I may destroy my daughter's laptop trying this. Hmmmm
IndroCruise
Thanks a whole lot for that information and the time it took to share it. I do have a bluetooth reader I use alot but nothing too sophisticated. Not even sure what all it will do. I checked for codes and found none logged or pending. However, that was when the pump would run at start up. Now it doesn't run at start up so I will check for codes again. No CEL showing presently.
I would strongly recommend you use the "techstream in 5 minutes" software and not whatever came with that cable. Use the cable by itself and the techstream Virtual Machine" software as downloaded in the ih8mud thread.
Roger that. Thanks alot.
IIRC don't upgrade to V15 of Techstream. Stick with 14. Experts will correct me if I am wrong.
