What a challenge that AHC issue was... I didn't take almost any pictures, as I was under lots of stress and covered in oil to the ears. Pictures here are from other posts, but are a good illustration.
First of all - if you are getting 1762 immediately after starting the car with a new pump - 99% the pump is not assembled correctly and is just spinning and not pumping anything.
The two notched cylinders in the bottom of the photo go around the two gears. They can go on either gear, but notice the indentation on the right one. It has to end up between the strainer and the indentation inside the rounded triangle ring. If it does not you can still assemble everything but no oil will come out.
Before installing the new assembly, 100% apply 12V to the motor and check that it is pumping out a steady stream of oil. It's not a particularly strong stream, but it is steady and shoots out at 10-15cm/4-6" (don't quote me on the exact distance)
Before installation 100% take the pump apart and clean it up. Lots of residue inside even on otherwise clean assemblies with clear fluid. The pump is super sensitive to blockage and contaminations. Those pumps run crazy high pressures - 7Mpa, which is the target front pressure is 70bar or 70 times the air pressure, or 700m underwater!
The strainers are extra fine in order to protect the gears and are easy to block, even with fine residue. If the pump is making screeching noises and/or the stream of oil is not steady, high chances are that it is at least partially blocked. I did not try to force them out, but blew them with compressed air.
Do not take the motor apart unless you really have to. 90% of the time the problem will be within the pump. You will need a press to put it back together or rig some ghetto system. The rotor shaft is pressed inside the output bearing, which is pressed inside the housing. The brushes are spring loaded and you can't put the rotor inside them, without first removing it from the housing. You will then have to press the brushes + rotor back inside the housing.
Mine is at 280k miles and it very well has > 50% of the brushes left and the commutator looks pristine. More or less exactly like the photo bellow.
The symptoms I had that were giving me a lot of grief:
- Active test does nothing - this was improperly assembled pump.
- Active test makes a lot of noise, but vehicle barely moves. Pressure barely reaches 1.5-2MPa - this was debris in the pump - a hair (!) and some strings, probably from the rags.
Make sure to manually bleed at each corner once the pump works well. Messing around with it, with the piping, priming it with air still inside, etc will add some air to the system.
