With the "rolling blackouts" that are happening and predicted, maybe a couple lithium batts plus converting your home appliances to 12V might be in order.
That's about what mine reads, but of course, it varies according to how long it's been setting without engine running or solar hooked up. With engine running, I've seen it as high as 15 volts. My starting batt is the old school lead/acid and will read about 14.6 volts with engine running. I've thought about the same issue with the length of my winch cables when I installed it and they will reach my starting batt in an emergency, but I'd be cutting a few wire ties...My reasoning for going with AGM for the house battery was the great longevity I have had with my AGM starting batteries. Averaging more than 5 years before any noticeable drop in performance. I did make sure my winch cables were long enough to switch to my starting battery if that is ever an issue. Winch does not get used that often. I did two short drives with the new battery this weekend. Alternator seemed to be charging it normally. Resting voltage seemed to be about 13.5 volts, if voltmeter is to be believed. I have not had time to do much research on solar or even home chargers, but I will get on that.
Now, having said all that, I also must admit that I don't know much about alternator design. I would be interested in knowing if there is a way to adjust the max voltage produced, maybe by tweaking something on the boards. Anybody knows?
But assuming it is not easily modifiable (I never heard it is TBH), that is also why a typical added charge controller (like a solar one or a DC-DC in vehicle charger) is useful for AGMs, because you can likely easily set up the charging cycle for specific AGM voltage needs with some of those.
^ yes, that would be about 0.6V for a silicon diode I imagine. Brute force! I like it! Although, I was thinking more along the lines of a pot someplace on the ICB to fine tune things.
The inherent problem with those approaches, though, is that it still does not deal well with having 2 different types of batteries connected directly to the same alternator. Interestingly, though, in the case of OP he is in a unique situation because he has 2 separate alternators IIRC, so he could modify only one of them. Yet, adding a whole 0.6V may be a bit much for an AGM.
I should add that one thing that just boggles my mind is that a LiFeP battery will actually respond pretty well to charging at 14.4V as well, so in a pinch it could charge OK (if not optimally) with the usual 14.4V alternator as well. Very convenient! What were the chances of that...?
Thanks for the heads up. So as to not hijack thread I'll look into it. Prelim research points to possible voltage regulator in alternator. Being that it's 27 yrs old and only thing I've done is replace brushes about 100k miles ago, I can't complain.^^^ I would be very surprised that a lead acid battery -whether AGM or not- would have a resting voltage of 13.5V if by resting you mean the usual "when the temporary charging effects such as surface charge have dissipated".
^ If my alternator were giving out 15V I would look into it / be concerned.
