I have a pair of Hella Supertones installed. No complaints.
I just re used the factory wiring.
Alright, I will give that whirl when I get home. Thanks!One tab is for the ground wire, the other is the positive. The ground can be wired to the radiator bracket.
I also love the Cadillac 4 tone setup ..
@Red Merle if you are facing the horns, and they are facing out at you
the tab at the 5 o'clock position is the +
the tab at the 7 o'clock position is the -
I simply used a jumper wire from the - of one to the - of the other, spliced them together and put a ring eye connection to the end. I then attached this to the radiator support by removing one of the factory bolts, setting it over the hole, then re installing the bolt.
Thank you! These are the type of instructions that I need. I had a heck of a time finding the right size ring connector last night, I had to go to 4 stores before I found them. I assume that's because all of you guys are rushing out to get new horns now.
I will hopefully get it rigged up tonight and let you know how it went.
Thanks again!
Did you just have to splice into the original horn wiring? Interested in how you did this as I originally looked into the setup.
Woohoo! Your instructions worked perfectly!A lot of times I will use a step-up bit to open the ring terminal. You just have to hold onto it with a good pair of pliers.
