Aftermarket fan clutch
Discussion in '80-Series Tech' started by mooker82, Jul 25, 2005.
  1. mooker82
    mooker82
    1,700
    24
    Nov 3, 2004
    Charleston, SC
    After checking with CDAN the OEM fanclutch is out of stock and on backorder until August 1 or so. I know everyone on here will recommend OEM but I am going to make a 300 mile each way trip this coming weekend. I dont want to do it without AC if possible (can't stand the whining from the GF). Has anyone installed an aftermarket one? Is the quality from one store (NAPA vs Autozone vs Advanced) better than the others? The part is only around $60 for an aftermarket one so if I buy it and install it I could switch to OEM later and not be out too many $$$ but would only do this if installation is not a PITA.
  2. e9999
    e9999 You want to do what...? Moderator
    16,737
    593
    Sep 21, 2003
    US
    can't you just bolt it blocked?
  3. CreeperSleeper
    CreeperSleeper Cascade Cruisers SILVER Star
    6,868
    707
    May 16, 2005
    Forest Grove, OR
    Install is easy. I just put a aftermarket one in mine and so far it is working fine.
  4. landtank
    landtank SILVER Star
    19,456
    1,834
    Mar 27, 2003
    Groveland MA
    I had a TorqueFlow on mine for about 50k, then the roar was gone. Got it at autozone. I must have got my order in to CDan just in time.
  5. mooker82
    mooker82
    1,700
    24
    Nov 3, 2004
    Charleston, SC
    I remember reading that somewhere. Supposedly made it sound like a jet engine at freeway speeds. I might give this a shot this afternoon just to see what it does.
  6. Tools R Us
    Tools R Us
    23,767
    5,501
    Jul 20, 2004
    Chandler, AZ
    Don't go that route with the stock fan, they are not made to spin at full RPM, the results of a fan coming apart at speed are not cheap! Ether get a clutch or a flex fan and adapter.
  7. mooker82
    mooker82
    1,700
    24
    Nov 3, 2004
    Charleston, SC
    Has anyone gone this route (flex fan and adapter). This seems to me like it would work better than the fan clutch. I know the downfalls to this setup would be increased parastic drag which would mean a less efficient system regarding MPG and such but would likely increase cooling.
  8. Tools R Us
    Tools R Us
    23,767
    5,501
    Jul 20, 2004
    Chandler, AZ
    I am not a big fan of flex fans, but they work. It will make more noise, they don't last that long and are a pain to install, the bolts will need to be 2.5"+, leaving very little room to tighten them.
  9. JZenger
    JZenger
    91
    Jun 13, 2005
    Salt Lake City, Utah
    I needed to replace mine pretty quickly so I just put in the Hayden fan clutch from Pep Boys and it has worked just fine. I have read posts from others who have used the Hayden as well. I will eventually replace with the OEM fan clutch. The Hayden fan clutch was only $65.00.
  10. e9999
    16,737
    593
    Sep 21, 2003
    US
    you guys make it sound like there is so much choice.
    do all these aftermarket clutches have the same bolt pattern or does the Toy use some sort of common standard?
