$145k, really? And with stretched out seat back netting and no extra cupholders$145K, without factory lockers....and steelies..
No details...no clue on the transmission for example. When it comes to swaps, details matter and how well it was implemented.
Everything else looks stock and decent. Very few aftermarket parts: alarm, horns, roof rack, sliders, motor, etc.
Did they do a good job painting? No idea. One would need a very close inspection.
This is what I saw from the pictures.
Pulled the rear heater but left the button?
Missing front skid plate.
Missing inspection plug on transmission bellhousing
I don't like the way they ran the transmission cooler lines underneath the bottom radiator support. They will get chafed.
I can't see a trans cooler...it is not in the stock location at least.
I don't like the way they ran the exhaust below the t-case. It is just a regular exhaust shop job....nothing special.
The cats hang low... Mine are tucked into the frame.
The fuel lines, running outside the frame, look sus. Band Clamps?
The rear brake lines are also run outside the frame....??? This is asking for big trouble...There is a reason why factory run them inside the frame, away from tires.
ABS deleted and the brake lines were manhandled...not a professional job
No power steering cooler?
Missing the plastic step for the 3rd seats.
The air box pulls air from where?
The washer fluid lines are weird, and not run in the factory location. It looks like they don't have the lines running to the rear wiper.
The front bumper isn't adjusted correctly on the driver's side.
That spare is hanging crazy low....
Are there still vin stickers on the body panels?
Removed rear window deflector, and also the factory roof rack.
Not a great install of the replacement carpet.
The replacement seat leathers look good.
The gas and hood releases are swapped.
Both knuckles appear to be weeping gear oil.
The rear lower controls have been recently replaced with OEM.
I prefer the OEM horns and not cheap aftermarket horns.
Replacement speakers don't look great.
The replacement washer bottle probably doesn't hold a gallon of fluid anymore...
Missing the rubber plugs for the battery box
There appears to be a fuel filter on the passenger side, right next to the exhaust. Odd location if that is what it is.
The oil pan looks really close to the front diff. The clearance there is something to watch for if you take it off road.
It was blank for me as well. I had to go to CORSETTI CRUISER LAND CRUISER FOR SALE - https://www.corsetticruisers.com/inventory first, and then click on the 80 series.The linked page to corsetti is now blank.
