- Thread starter
- #61
Final drive is much lower . One of the downsides but not bad at all. I cruise around 2800 70-75 mph
Yes haven't found any direct bolt ons to swap them yet but so far haven't been a limiting factor. Honestly fuel system was probably fine stock with slightly larger injectors but return line was just to small for big fuel pump and caused weird pressures.Are you using the stock fuel rails still?
Have you found a rail that would work? At what point do you think it would be needed?Are you using the stock fuel rails still?
Thanks. It's coming along . Costing a fortune for all the small things but have to get my wrenching fix somehow in parking garage haha.Damn that thing is rowdy! Looks like new too.
Short Answer is from what I can tell its hit or miss depending where you go. Last inspection I just took mine to an off-road shop. They clean it up , charge for their time and they took it for me to an offroad "friendly" test center. RAMY Auto is the shop. They do tons of Jeep Superchargers and also wrote some articles on getting it RTA approved. Seems all that was a big hassle and easier to just install it properly dont run open exhaust and they can get it passed without the RTA certification. Same as all of Dubai. PAY to PLAY. Who really knows. Could be pulling the SC on the next inspection.Hi WP. Just really curious as to whether you are seeing any issue with RTA on the annual inspection. I recall articles a couple of years back where folks with modified engines were supposed to get some kind of sign off by a place down in Abu Dhabi. I looked into it a little and really could not make sense out of the whole process...
Thanks WP. I'm mid-project on the swap of a 1HD-FT for a 1HZ and the reverse for two 80 series. Part of the reason I've been thinking of this is a curious animal recently on local auction:Short Answer is from what I can tell its hit or miss depending where you go. Last inspection I just took mine to an off-road shop. They clean it up , charge for their time and they took it for me to an offroad "friendly" test center. RAMY Auto is the shop. They do tons of Jeep Superchargers and also wrote some articles on getting it RTA approved. Seems all that was a big hassle and easier to just install it properly dont run open exhaust and they can get it passed without the RTA certification. Same as all of Dubai. PAY to PLAY. Who really knows. Could be pulling the SC on the next inspection.
Others who dont want to pay or go to wild on their build just remove, install stock, pass RTA and reinstall. Labor at shops here for that type of work is very cheap as Im sure you know.
Swapped to Bosch 82mm TB for full drive by wire. Pedal from 2003 worked great.
About 1/2 smaller. I'll measure it today now that it's off.How big is the factory TB?
