Adding SC to my 99 GCC build thread
New rotors and SC service before putting it back on for testing and retune.
New fuel rails from Elate Mfg. 1050x injector dynamics, recoated rotor pack. To bad I'll only be driving it a few more weeks then leaving country for few months break. When I'm back in Dubai I will be pulling the TRD to swap for new Superchager and Intercooler from Elate Mfg.
Starting new addition to my long running project next week.
Custom Elate intercooler and Harrop SC going in and TRD coming out. TRD still running great just looking for more boost potential and cooling for later if I decide to upgrade internals.
Is that heat blanket under the manifold how it came or did you add that? Also I wish I added an intake air temperature sensor under there when I had the chance but forgot to do it. If I have to lift the blower again I'll add it.
Came with the heat tape (no runner extensions on mine since it doesn have air injections) and yea definitely had to add my temp sensor post blower same as TRD. Will post some temp data once it's done. I hade Elate make me a 60mm cooler to help with the extreme heat here but probably overkill.
External fuse box swap. If you hate dealing with clicking relays and melting fuses this MSD solid state relay is great. Can also PWM any output (slow down electric pumps, fans etc)
