Back in before anyone could respond
Got up early Saturday and started the real bleeding. I also timed the booster motor run times a little more carefully. First i wanted to point out a couple of things to anyone else doing this job.
1 - It took a long time for my dash lights and audible alarm to finally turn off and go back to normal. My guess is that this is due to the brake pressure sensor not building up sufficient hydraulic pressure until you have the major brake components nearly fully bled of any air. It will likely take the better part of 2 quarts of fluid added to get enough fluid back into the reservoir, master cylinder, pump and accumulator before your audible alarm will stop.
2- I used 4 full 32 oz quarts of Valvoline DOT3 fluid plus a few onces of another bottle i had on the shelf to fully bleed the entire system. I would recommend if you are shopping for parts to get 5 quarts.
3- I have two mini-me helpers so pressing the brake pedal, watching the fluid level and actually cracking the bleeders under the truck is a relatively well coordinated process. It helps to have help.
4 - Build the brake bleeder bottle before you try to do this with any other tube-and-bucket "hacked together from what i had laying around" brake fluid collection method. I did not, and one on of my "cycle the ABS" drives i went to two auto parts stores trying to find the clear/yellow fuel line i needed. Found it at O'reilly in Georgia and bought an Orange Fanta for the mini-me companions to drink on the way home. That hose, two drill bits and three sugar drink filled tummies later and i was kicking myself for not having built that sooner. You garage floor will thank you for building yours before you start this process.
5 - The most frustrating part of the entire process for me was actually getting the brake booster/accumulator/reservoir/master cylinder assembly back into the engine bay and into place on the firewall. Dealing with 4 hard hydraulic lines, 4+ electrical connections, and numerous vacuum lines was difficult and i was worried i was going to kink something. You will need good lights and a ladder to be able to maneuver this assembly back into place. i put a mini-me upside down in the drivers seat ready to thread the 4 nuts on as soon as i got it all through the holes and into place.
6 - While waiting for the booster motor to ship out, get rebuilt, and returned i should have, at a minimum, rebuilt the brake calipers/pistons, turned rotors, and replaced the brake pads. If i was going to do this again, i would plan on doing a full brake pad/rotor job, rebuilding the calipers, and if stainless steel brakes lines are your thing, might as well check that box too. With all the bleeding and fluid i went through those extra steps would have been no big deal. This electric motor rebuild is the long pole in the tent from a down time standpoint and you are looking at about 7-10 days downtime minimum. Mine took longer because i tried to find a local shop that could rebuild the motor and i was doing this in the middle of an election and Thanksgiving. If you live near any city with an Industrial base, there are likely local shops that can rebuild industrial electric motors, but the commutator on this motor is going to be what throws them off and may ultimately cause them to decline the job. I ultimately called, emailed, sent pics and shipped my motor to M & M Forklift in St. Louis. $190 plus ~$45 total for insured shipping both ways. My truck was out of commission for 3+ weeks total, and that is plenty of time to take care of some major maintenance/upgrades in the drive line. We did this during the pandemic so i didn't need to travel to an office everyday, and have 3rd vehicle as a spare so i was very blessed to not be rushed during this process. Even 2+ weeks of downtime is plenty of days to swap out the CV axles in the front (both of my outer boots are completely torn), and possibly even taking off the front and rear diff's to send them to the guy that does e-locker installs.
7 - On my cruiser the front break bleeder screws are longer than the rear, and the new ones i bought was a set of four rear bleeder screws. While this worked, the front bleeder is recessed further into the wheel well and you run a greater risk of rounding over a couple fo corners on the bleeder screw. There also isn't enough room to fit a flare nut wrench on the front bleeder screw if you replace them with the short bleeders. If i did this again i woudl order 2 {short} rear bleeder screws and 2 {long} front bleeder screws.
