ABS brake actuator pump for 1997 FZJ80 Tank (part #44510-60010)
Fayetteville, Arkansas
Greetings, Land Cruiser gurus,
The brake actuator pump on my 1997 FZJ80 (part #44510-60010) has failed and requires replacement. My local Toyota mechanic says that it's an obsolete part that's no longer available from Toyota, but that if I could find a used one, he would be glad to install it. I've found some on E-Bay, but all the ones I've seen so far are for FZJ80 models with LOTS more miles than mine has -- which makes me feel as though I would be jumping "out of the frying pan and into the fire." Does anyone know where I can purchase a new one, or at least one that has been rebuilt or remanufactured? At the very least, just finding one that someone has carefully inspected and determined to be in good serviceable condition would be better than nothing. Thanks in advance for any assistance you can offer in this matter.
Philip Thompson (a.k.a. "PolarBear")
I have a used one with less than 200k on it I would sell cheap. I deleted abs and have never been happier with the brakes on the truck, but the abs pump was working fine. Its not a part that fails frequently, most are removed because they are difficult to bleed and lead to a mushy pedal feel once they get air in them. I would have no problem installing a used one - just like anything, I would rather have a good used OEM part than any non-toyota reman.
A couple of people who have removed their ABS units sent them to me for free with me paying shipping. Mine has a non-operable electric motor.
Just follow the threads about deleting the ABS to find someone willing to send you theirs. Otherwise, they just toss them.
Of the two that were sent to me, one had a bad electric motor, but the other was fine.
The electric motor can be rebuilt (>$300) but no guarantee that the rest is good.
I will probably take the bad one apart to see how it is designed and to see if it is repairable.
It's possible that your ABS pump failed in the same way that mine did, which means it's an easy DIY fix. Basically, it's pretty common for loose rust to block the motor and all you have to do is clean the rust out and then the pump will work fine again. After cleaning and application of rust converter my ABS pump has been working well for 5 months and should be good for years to come.
I posted more information and a photo on this here:
Yes, please let me know how much you want for the pump; I think I'd like to purchase it.
What makes you think the pump failed?
The pump is available. It took me 4 months to get one in but it is available. Maybe at the time the were out of production.
Where did you order your from, if you don't mind me asking? I replaced mine with used a few years back but it's failed again, and puked debris into the master cylinder and reservoir. I've found the part online at a few dealers, but the price varies a good bit.
Did troll ever get back to you on where he got a new one from?
